Transmission & Drivetrain Gearboxes, Differentials, Clutches
Replacing ISB Problem, can't remove main shaft
Old Mar 7, 2016 | 07:52 PM
jonslam's Avatar
Default Replacing ISB Problem, can't remove main shaft
in the midst of changing my input shaft bearing for the first time I got everything done easily until getting off the main shaft. I've removed the reverse shift holder and reverse idler shaft and everything else that needs to be removed. Ive been following a write up and all I have left to do is lift out the main shaft and all those goodies, but mine doesn't wanna come out at all I've been at it for 2 hours now. Wiggling it shaking it you name it.. what am I doing wrong or is there any tricks to help.
Thanks!
Old Mar 8, 2016 | 10:17 AM
Aquafina's Avatar
Default Re: Replacing ISB Problem, can't remove main shaft
B series remove the shift change piece, D remove the bolt from the shift arm and make sure the interlock guide bolt is out. If it still won't come out, tap it from the clutch side with a dead blow hammer.
Old Mar 8, 2016 | 10:30 AM
jonslam's Avatar
yeah I've removed everything for b series and still won't come out, I guess I'll try the dead blow hammer.
dascivic96
37
May 7, 2012 03:36 PM
dleccord
Jan 10, 2010 03:35 PM
welfarepc
Feb 3, 2007 07:02 AM
Ivan
Feb 9, 2006 12:22 PM
MeanGreenEG9
Mar 17, 2003 06:24 PM
