96 coupe/OBD2 Jdm d15b vtec swap - EVAP and knock sensor CEL codes
Old Feb 29, 2016 | 06:56 AM
Hoghunter25's Avatar
Default 96 coupe/OBD2 Jdm d15b vtec swap - EVAP and knock sensor CEL codes
Ok guys I'm new to this site an new to the d series. I have a 96 coupe an I have a Jdm d15b vtec with obd2. It have one solenoid, 4 wire o2 an p2p ecu. My code scanner keeps pulling up evap low pressure, an knock sensor. What could be the problem? Maybe wrong ecu?
Old Feb 29, 2016 | 07:25 AM
Former User's Avatar
Default re: 96 coupe/OBD2 Jdm d15b vtec swap - EVAP and knock sensor CEL codes
Do you have Knock sensor connected to the ECU?
What is the specific EVAP code?
Old Feb 29, 2016 | 07:35 AM
The forums say the d series doesn't have a knock sensor. An the evap jus says low pressure
Old Feb 29, 2016 | 07:59 AM
Some D-series do have a knock sensor (e.g., D16Y8).
There's an evap code number. Post it.
What trim is your 96 coupe? DX, EX, HX?
Old Feb 29, 2016 | 09:55 AM
Okay I found the evap problem. It was two places on the intake capped off. I put a 3 way on it an some hose an the code went away an now the idle is down where it's supposed to be. An so the jdm d15b should have a knock sensor?
Old Feb 29, 2016 | 10:02 AM
mk378's Avatar
The knock sensor screws into the back of the block near the alternator. All D series blocks have a raised place there in the casting for it, but oftentimes the hole is not finished and tapped.
You can sort of rig a knock sensor by mounting it anywhere and hooking up the wire, which will keep the CEL off, but if it is not securely attached to the engine block it can't actually detect knocking.
Old Feb 29, 2016 | 10:46 AM
Default Re: 96 coupe/OBD2 Jdm d15b vtec swap - EVAP and knock sensor CEL codes
It's a EX coupe. An oh okay I gotcha man. An yeah I seen the plug for it laying on top of the alternator but could never find the sensor. But okay that helps a lot thanks man. An would you know how I can find out the year of my engine?
Old Feb 29, 2016 | 10:51 AM
There should be a year code stamped on the head.
https://honda-tech.com/honda-civic-d.../#post48684945
https://honda-tech.com/honda-civic-d...-here-3210150/
Old Feb 29, 2016 | 12:28 PM
Okay how about this. This is what I came up with. My head says p08-2 an my block says d15b. So what the hell is this lol?
Old Feb 29, 2016 | 12:34 PM
Fits with JDM D15B VTEC, probably OBD1.
What's the year code on the head?
No knock sensor on the block?
Old Feb 29, 2016 | 12:37 PM
9/2. So I'm guessing a 95?? An nope no knock sensor. I found the plug that goes to it but the hole isn't drilled
Old Feb 29, 2016 | 12:41 PM
1992
Fits with OBD1 JDM D15B VTEC.
Do you live in the U.S.? If so, what state? You may want to find out whether you can pass emissions with an OBD1 ECU. Other members may also know whether the engine will run well with a P2P ECU if you install a knock sensor (KS).
Old Feb 29, 2016 | 01:46 PM
Oh okay. Well I live in Mississippi we don't have any laws like that. I use to run open pipe lol. Jus noise ordinance tickets. An yeah it has the p2p ecu. But yet it have a obd2 plug that I use to scan an found those problems. It don't have a adapted harness or nothing to the ecu. I'm really confused on what I have. How can I post pics for you to see?
Old Feb 29, 2016 | 01:48 PM
Press this button...
...and then drag and drop pictures on your desktop into the browser window.
Old Feb 29, 2016 | 07:26 PM
Old Mar 1, 2016 | 01:40 PM
HondaPartsHero's Avatar
Technical Hero
Only the OBD2 d series have the hole that is tapped for knock.
Old Mar 1, 2016 | 01:49 PM
Oh okay good deal. Could you tell me what rebuild kit I would need to do this? It runs fine jus high in miles an using a bit of oil
Old Mar 1, 2016 | 01:54 PM
Does this mean that the head is OBD1 and block is OBD2?
Old Mar 2, 2016 | 10:19 AM
Yeah I do believe so. An is this considered the mini me ?
Old Mar 2, 2016 | 10:24 AM
Possibly, assuming that the original OBD2 head was non-VTEC.
swirve1
Jan 23, 2010 08:25 AM
BEATurBOYS
Dec 18, 2009 07:16 PM
04silvep3
Feb 3, 2009 11:27 AM
b18cEF9
Dec 20, 2004 04:22 PM
