Rpm issue with hondata
Old Feb 26, 2016 | 02:09 PM
JTECHDC2's Avatar
Default Rpm issue with hondata
I installed a Rywire jumper harness into my 01 R with a hondata obd1 and my Rpm is not working. I heard I had to jump some wires in the jumper harness. Has anybody done this? and which wires or show me a pic of how is done. Thanks.
Old Feb 26, 2016 | 02:40 PM
Runnerdown's Avatar
Default Re: Rpm issue with hondata
Over on the harness near the clutch reservoir there is a blue wire in a blank connector. It's taped to the main harness so you have to dig a little bit for it. Connect to that and run a wire over to the distributor plug. On the distributor side there is an un-used blue wire that has tach output. Connect these two together and you will have reliable tach signal.
epingquian
Mar 29, 2018 08:29 AM
ramco
Jan 8, 2012 05:13 PM
uvamosk
Engine Management and Tuning
Jul 7, 2011 12:08 AM
nonvtec
Apr 5, 2005 11:11 AM
GDM Z28
Apr 9, 2004 10:40 PM
