Honda CR-V & Element 2WD & 4WD Element & CR-V
Will this work in a 1998?
Old Feb 17, 2016 | 09:04 AM
Tootsie7944's Avatar
Default Will this work in a 1998?
http://www.ebay.com/itm/99-01-CRV-RT4WD-AWD-5-Speed-MT-Manual-Transmission-Trans-Swap-Conversion-B-/321937728306?fits=Make%3AHonda%7CModel%3ACR-V&autorefresh=true
Says it won't work. I know that year had the B20Z motor, but shouldn't this all bolt up and run with the B20B as well?
Old Feb 17, 2016 | 05:55 PM
LDForget's Avatar
Default Re: Will this work in a 1998?
pretty sure the only difference would be the ECU, as the z motor has a knock sensor and a few different things in it, so you would have a check engine light. just run a obd1 ecu with a b20b basemap and an adapter harness.
Old Feb 18, 2016 | 08:17 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Yes, everything except ECU. It will definitely all bolt up.
civicman361
Engine Management and Tuning
Apr 3, 2014 10:38 AM
jonyi27
Jul 1, 2013 09:29 PM
almostjdmeg
Nov 15, 2009 07:28 PM
esoterEK..
Apr 25, 2005 11:33 PM
hybridreams
Jan 5, 2002 10:08 AM
