D16Y7 engine swap help please.
Old Feb 10, 2016 | 07:56 PM
Actorus's Avatar
Default D16Y7 engine swap help please.
i have a 1999 Honda civic which had a d16y7 in it when I got it. engine blew so I'm looking to buy another engine. I found an engine on ebay stating the engine is a "ZC" says it is compatible with my car but my question is, would it be plug and play. will it run off my y7 ecu and wiring?
Old Feb 11, 2016 | 01:40 AM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: D16Y7 engine swap help please.
stay away from ebay for engines. usually inflated prices and shitty dealers. car-part.com, plug your zip code in, buy a local y7 with a warranty.
Old Feb 11, 2016 | 07:01 AM
Actorus's Avatar
okay but could you please find out if its possible to run other engines with my current ecu?
and the one I found was $749 looks very clean with 55k miles on it.
Old Feb 11, 2016 | 08:22 AM
OxDseries's Avatar
If you install an engine D series (eg: Z6,Y8, D15B) with vtec system, its not gonna work... Basically any D15/D16 non-vtec will run fine.... But to keep good Hp/tq get a D16 one...
Old Feb 11, 2016 | 08:39 AM
tony_2018's Avatar
Fish Twig
itll work, just run like ****
Old Feb 11, 2016 | 09:17 AM
Actorus's Avatar
from what understand the y7 and the zc are both non-vtec, so my ecu is for the y7 so its not vtec. but as long as the zc I'm looking at is a non vtec it will work with my current ecu?
Old Feb 11, 2016 | 10:12 AM
OxDseries's Avatar
:Scared: There are both SOHC and DOHC ZC engines. The non-VTEC SOHC ZC is similar to the D16A6 ('91–'96) and D16Y4 ('96–2000) engine, but with more aggressive cam timing. The SOHC VTEC ZC is similar to the D16Z6 ('91–'96). The DOHC ZC is similar to the D16A1, D16A3, D16A8, D16A9 and D16Z5 engines.
So Witch one you have ??? you can use your gearbox and everything else without a problem... the only issues you will have is the Vtec ain't gonna work....
Old Feb 11, 2016 | 12:14 PM
untrue. vtec zc will want a 2 wire iacv, he has a 3 currently. if he swaps vtec, he'll need to add a knock sensor as the ecu will want it as well. OP- if you believe those mileage claims, i have a motor in my garage with only 30k miles.
Old Feb 11, 2016 | 01:09 PM
f15Civic's Avatar
Why do you want a ZC? Like the other mentioned, just get a a D16Y7 and make your life easy.. You should be able get a new (Used) one depending on your local market for 300-500.
Old Feb 11, 2016 | 01:44 PM
OxDseries's Avatar
Definitely Vtec ones need lots of work to do than just install it... so he cant use his current intake manifold, the Y7 one, Plug and play on the ZC head... too bad...
Old Feb 11, 2016 | 07:20 PM
why go thru that **** when the y7 is the cheapest and most abundant d16 engine?
Old Feb 12, 2016 | 11:18 AM
f15Civic's Avatar
Exactly
Old Feb 12, 2016 | 12:24 PM
NotARaCist's Avatar
I never narc'd on nobody!
I'm curious how you know the engine is "blown", and exactly how it's "blown". If it's something as simple as a head gasket replacement, why are you even considering a new engine? Good chance you can get out a lot cheaper by fixing, rather than replacing with an unknown engine.
JoanaFabio
Jul 7, 2018 01:26 PM
Adamr2014
Apr 26, 2018 10:47 PM
Topher75
Honda Civic (2001 - 2005)
May 28, 2013 05:09 AM
CustomCivic
Aug 29, 2008 05:32 PM
test_drive
Jul 12, 2004 04:40 AM
