has anyone in here ever had there motors powdercoated?
my friend here has no luck what so ever.....had to take care fo my lil bros could come over ill get in touch tomarrow man think i have an idea for ya
ok im just looking for an answer on my question.thanks for the concerna bout the heat but that is the least of my worries at the moment
That should be the biggest worry actually... whats the use of spending all the money on a motor, have it powdercoated, and then have it overheat... just money wasted...
To get the electrical grounds to work, just scrape away the powdercoat in the area you will have grounds going to... the lines will cover the little bits of powdercoat you flake off...
Ya, he wants to powdercoat the block...
Why would Powdercoating do anything bad? Are you serious?
V8 Guys have painted their blocks for decades.
Powercoating is the same thing, just more durable.
Suprdave
Suprdave
Powdercoating is a bit thicker and the reason it sticks so well is because its particles fit tighter, making it harder for air to come in and out between the particles... where as regular ol' paint is alot looser and prone to cracking and flaking... get what Im saying?
powdercoating was already done.maybe im not asking the write way
[Modified by civbeater90, 12:15 AM 11/9/2002]
you see ther in lies the problem.i have spark and fuel crnaks but nostart.im wondering if the tranny case causes too much resitance or something.i cannot figure out what is worng.also timing is dead on.
the sad part is i still have to break in the motor for all the turbo crap i have sitting in my garage.
If your anywhere near Central Florida I would love to come by and help you out with the car... Like I said, scrape away all the powdercoat where you will be grounding...
yeah where the starter sits there is no paint already.still the problem continues.thanks for the help but im in nj.
slacks
10
Mar 23, 2008 03:10 PM
