93 DelSol head question
Old Feb 3, 2016 | 12:57 PM
gisl's Avatar
Default 93 DelSol head question
Hi,
I have a 93 DelSol S with 1.5 engine that is in need of a replacement head soon. Can someone tell me, did Honda make more than one head for this engine?
If so, where are the casting numbers located on the head and do I need to remove anything to read them (like the heat shield etc.). Thanks.
Old Feb 3, 2016 | 01:20 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: 93 DelSol head question
More than one head for the D15B7 that's in your car? No. They made other heads that can be made to work, but there's only one type of D15B7 head. The casting code is on the front of the head, above the exhaust manifold. Don't need to remove anything other than dirt to see it.
Old Feb 3, 2016 | 01:37 PM
gisl's Avatar
Great! That is where I looked for the code, but I did not see it. I thought perhaps the exhaust heat shield was covering it. I will look again.
Old Feb 3, 2016 | 04:03 PM
White_EG1's Avatar
Yeah take the heat cover off... D16a6 head is very identical and will give it a little extra pep. Make sure you get the a6 cam with it, You can find those on the 90-91 CRX Si's.
Old Feb 3, 2016 | 10:55 PM
hondur's Avatar
Dur Da Dur
5 Year Member
a y7 cylinder head will bump up the compression like a z6 mini-me, without the hassle of adding vtec. skip the y7 manifolds, though.
Aquila
May 15, 2016 07:33 AM
P.Raickovic
Mar 13, 2016 02:53 PM
Headman
15
Jul 19, 2013 12:37 PM
Z0831xiz
Jun 25, 2013 09:46 PM
djspecter
29
Dec 9, 2007 06:46 PM
