Help z6 turbo won't start
I have a z6 that is turboed it has good compression all across the board .has fuel. Has spark turns over but will stop mid crank then continue to turn over I drove it around it was rich it is untuned atm. Drove fine then I fouled the plugs shut it off and bam will not start since then please lead me in a direction I am lost
Untuned
It's that time of year, isn't it? We're going to be getting a large influx of tax return dummies doing dumb stuff.
"Good compression" is diagnostically useless. Exactly what are the numbers? Repeat the compression test, adding a small bit (teaspoon) of oil to the cylinders - what are the numbers now? Like RonJ said, pull and post CEL codes.
severe97
16
Nov 6, 2007 05:34 PM
