Compression test... searched
Old Sep 28, 2003 | 03:01 AM
J-g-D-s-M-r's Avatar
Default Compression test... searched
i finally got around to doing a compression test. 200 190 190 190. i don't think that was bad at all. so i put everything back together. decide to start up my car to get food. and bam. car won't start. so i check rechecked and double check my plugs and cables. everything is correct. it cranks up but won't start. now my car is like completely dead. battery died out from running a bunch of different tests. i know i needed a new altenator, but that wouldn't stop my car from starting. i mean it started like 2 hrs before the compression test. ive tried changing spark plugs and wires. nothing worked.... my distrubitor is working... i mean it just doesn't die in 2 hrs... while it's parked too. anyone have any idea or have experienced this?? sorry for the long post. TIA
Old Sep 28, 2003 | 06:27 AM
tilt's Avatar
Default Re: Compression test... searched (lDarkCloudl)
did you pull the fuel injector plugs/fuse when you did the test? If you didnt, my guess would be the cylinders are flooded.
Old Sep 28, 2003 | 07:45 AM
SIanara's Avatar
i'm not sure that the problem could be, i dont know what the procedure is to do a comp. test.(i need to do one though)i could only guess that a conncetion is bad or a fuse is blown. have u tried POP starting it?
Old Sep 28, 2003 | 11:18 AM
Default Re: Compression test... searched (tilt)
i did try pop starting it.... didn't work. that might be it. my cylinders are probably flooded.. i don't recall pulling the fuse. what do i do now??
Old Sep 28, 2003 | 12:41 PM
AzG35's Avatar
If the cylinders are flooded, take out the spark plugs, disconnect the ecu or pull the F/I fuse, and crank it over about 10 times or so. This will circulate anything in the cylinders through the exhaust. Clean the plugs if necessary, and try starting again.
Old Sep 28, 2003 | 11:57 PM
Default Re: Compression test... searched (AzSi22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzSi22 &raquo;</TD></TR><TR><TD CLASS="quote">If the cylinders are flooded, take out the spark plugs, disconnect the ecu or pull the F/I fuse, and crank it over about 10 times or so. This will circulate anything in the cylinders through the exhaust. Clean the plugs if necessary, and try starting again.</TD></TR></TABLE>
tried it. didn't work. any other ideas??
Old Sep 29, 2003 | 02:32 AM
asianspeed's Avatar
My vote is you flooded it too, espcially if you didn't pull the fuse before you did the test. I'd try removing the plugs and the fuse and crank it more......that's got to be the reason. good luck
TylerC161
May 15, 2008 05:18 PM
severe97
16
Nov 6, 2007 05:34 PM
Bngo731
Jun 5, 2006 02:42 PM
xhimurakenshinx
Apr 2, 2005 06:36 PM
mugenracer
May 19, 2002 02:29 PM
