99 lx to zc swap
Old Jan 28, 2016 | 11:54 AM
99sohczc's Avatar
Post 99 lx to zc swap
hi there fellow Honda lovers I'm very new to this site so please be patient and bare with me.. this is my first swap I try... I have installed a zc single cam vtec engine on my 99 civic lx... let me tell you where I'm at with it... I bought a distributor for it and some plugs don't seem to match with my old wire harness at least one of them... now the engine turns but wont start.. can that one plug be the issue? do I have to change the wire harness out? if so from what car? what can the issues be? please help as in im new to all this..
Old Jan 28, 2016 | 12:00 PM
99sohczc's Avatar
Default 99 lx to zc swap
Old Jan 28, 2016 | 01:25 PM
tony_2018's Avatar
Fish Twig
Default Re: 99 lx to zc swap
Pics...what yr distributor....what engine harness...so much **** missing....**** this...
Old Jan 28, 2016 | 02:55 PM
99sohczc's Avatar
[I]This is 95 del sol distributor.. Stock 99 lx harness...
Old Jan 28, 2016 | 03:00 PM
99sohczc's Avatar
Engine is all in and everything bolted stock lx tranny.. P2e computer which is stock everything was supposably direct fit.. i upgraded the motor mounts to hasport
Old Jan 28, 2016 | 03:02 PM
99sohczc's Avatar
Just says zc...
Old Jan 28, 2016 | 03:05 PM
99sohczc's Avatar
Vtec solinoid missing but working on getting one as to have it wired...
Old Jan 28, 2016 | 03:09 PM
99sohczc's Avatar
[I]There she is everything is connected except tht distributor pic that i cant figure out if i have to buy a jumper harness or a whole harness from another vecicle ... like i said it turns but wont start.. Thanks in advance for anyone helping
Old Jan 28, 2016 | 03:10 PM
99sohczc's Avatar
There she is tony i posted some pics thanks for your reply bro i appiciare it..
Old Jan 28, 2016 | 03:12 PM
99sohczc's Avatar
Old Jan 28, 2016 | 03:22 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Your VTEC solenoid isn't missing. It's the oil pressure switch that is.
The green plug pictured below is the oil pressure switch. It's part of the VTEC solenoid.
eH.
Old Jan 28, 2016 | 04:09 PM
99sohczc's Avatar
[QUOTE=eHMxhACk;50743399]Your VTEC solenoid isn't missing. It's the oil pressure switch that is.
Oo right... Thankx... My bad the one that comes out of the block is also missing. other than that everything is good, just wanna know why isnt it turning on...
Old Jan 30, 2016 | 02:00 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Moved your thread as swaps is not really engine building etc.
You can get decent diagnostic help in the 92-00 civic section as that is what you are doing your swap on.
Thanks.
Old Jan 30, 2016 | 03:09 PM
24TEN's Avatar
PHANTOM MENACE
Which specific distributor did you use?
EDIT: OP has two threads for the same thing, please lock/merge as necessary.
https://honda-tech.com/honda-civic-d...-swap-3269140/
Old Jan 30, 2016 | 03:20 PM
24TEN's Avatar
PHANTOM MENACE
Rule of thumb, match distributor to the ECU to keep things simple. I believe OBD1 to OBD2A wiring is the same but they made a single plug for the newer distributor. The OBD2B wiring difference I believe is the elimination of tach signal. You also have a difference of flange too if that ZC has the 92-95 "P08" head.
With that said, I'm not near my car right now but I believe the smaller of the two plugs for an OBD1 distributor has the power wire. Your distributor pictured doesn't have anything connected to this plug. That might explain why your car won't start at the moment.
GameBoyeas
Jun 5, 2017 05:25 AM
99sohczc
Jan 29, 2016 12:56 PM
Bern0428
12
Jan 11, 2013 09:49 AM
~sp33~
12
Mar 12, 2011 08:20 PM
rafimos
Feb 24, 2004 04:33 PM
