Rod bearing clearence
Old Jan 25, 2016 | 08:43 AM
carlos8's Avatar
Default Rod bearing clearence
Hi, Rebuilding my LS/VTEC turbo, and I'm having a hard time with the rod bearings. I tried ACL race STD and King STD and the clearances are way off.
ACL's Race STD
https://honda-tech.com/attachment.ph...1&d=1453743803
I'm getting .001 on the green plastigage.
Old Jan 25, 2016 | 08:53 AM
turbohatch96y7's Avatar
ACL's Race STD
Too tight go with the acl hx bearings
Old Jan 25, 2016 | 09:04 AM
carlos8's Avatar
Default Re: Rod bearing clearence
What's the difference between H and HX.
Sorry for the question but this my first time working with ACL.
Old Jan 25, 2016 | 09:54 AM
NotARaCist's Avatar
I never narc'd on nobody!
The HX's are a wee bit thinner, to give more clearance. Honda has red, green, blue, blah blah all those different colors. ACL has H, and HX.
Old Jan 25, 2016 | 10:39 AM
I think its a thousandths
Youll end up around 0.019 or 20
I needed to do this before
Old Jan 25, 2016 | 10:55 AM
carlos8's Avatar
Last try if not, I'm going Honda.
ACL Aluglide STD.
https://honda-tech.com/attachment.ph...1&d=1453751708
Old Jan 25, 2016 | 11:00 AM
NotARaCist's Avatar
...Why are you still trying with standard sized bearings?
Old Jan 25, 2016 | 11:02 AM
carlos8's Avatar
This look better.
https://honda-tech.com/attachment.ph...1&d=1453752159
Old Jan 25, 2016 | 11:06 AM
carlos8's Avatar
I don't have the equipment or the knowledge to select the OEM ones.
I've reading threads how to but, I'm a little confused.
Old Jan 25, 2016 | 11:35 AM
You need inside and outside mics to get the right bearings
"Build it tight and everyone knows, build it loose and nobody will know"
Old Jan 25, 2016 | 12:12 PM
NotARaCist's Avatar
Assuming the crank and journals haven't been fucked with, the crank and block will both have stamps on them. Use that, in combination with a table in the FSM, and it'll tell you exactly what color OEM bearings you need.
Old Jan 25, 2016 | 12:19 PM
blackeg's Avatar
even after that you can probably go a color or so looser. I use the hx's for my rods they as hatchy said they usually get between .0018 and .002. ive found they measure right about between oem pink and red.
Old Jan 25, 2016 | 12:44 PM
diatibe24's Avatar
Have you checked the crank shaft rod journals to make sure it is in OEM spec?
Old Jan 25, 2016 | 03:20 PM
SPOOLINmatt's Avatar
hell you can do it all with a 40$ mic from advance auto parts much better than with plasti
Old Feb 2, 2016 | 06:55 AM
carlos8's Avatar
So, After a week waiting for the 3 days express delivery I get my bearings.
ACL HX STD. and about .0017 - .0018 all of them. A shy little than .0015 and a little bigger then .0020
https://honda-tech.com/attachment.ph...1&d=1454428461
crashsvg
Jan 9, 2014 05:30 AM
namm
May 6, 2009 09:06 AM
IN VTEC
Mar 18, 2006 08:40 PM
RACEPAK
24
Nov 9, 2005 11:08 AM
