Crank No start 98 Civic
Old Jan 25, 2016 | 08:07 AM
Travlash's Avatar
Default Crank No start 98 Civic
I have a 98 ex civic. I had been experiencing a fluctuating idle again so i figured i would clean the IAC. I sprayed some carb cleaner into the IAC and some into the intake manifold. Let it sit and went inside. About 6 hours later went out to start the car and it would turn over but cranked. Went under the hood and found that i didn't plug the IAC back in. So I did that and tried to start. Again just cranked. Started to smell fuel so i thought i may have flooded it. Took the plugs out and dried them and sprayed the cylinder walls with air. Let it sit, then the car started but immediately died out. The car has spark, starter is good, fuel pump is good, i don't know what to do. I also did noticed the Crank Fluctuation Sensor was bar from being caught in the alternator belt. So i re wired that. Just took the plugs out and left the iac off. I will try again later. Any help ?
Old Jan 25, 2016 | 08:15 AM
Former User's Avatar
Default Re: Crank No start 98 Civic
CEL codes?
Is spark bright white at all 4 plugs?
Does the fuel pump prime?
Old Jan 25, 2016 | 08:23 AM
Travlash's Avatar
I don't think there is any codes, i can't tell atm because i unplugged the batter. The spark is bright white at all 4 plugs and the fuel pump does prime.
Old Jan 25, 2016 | 08:25 AM
Reconnect battery. Crank engine for 30 seconds. Check for codes.
Old Jan 25, 2016 | 08:27 AM
Travlash's Avatar
No codes...
Old Jan 25, 2016 | 08:31 AM
Compression test the cylinders.
Old Jan 25, 2016 | 10:01 AM
Travlash's Avatar
all cylinders between 120-140
Old Jan 25, 2016 | 10:12 AM
List for all 4 cylinders.
Old Jan 25, 2016 | 10:55 AM
NotARaCist's Avatar
I never narc'd on nobody!
And while you're doing that, rent/borrow/buy a block testing kit. You can find them at any major parts store. 120 is extremely low.
lovemyhonda1
Sep 18, 2013 11:56 AM
olegles11
15
Feb 23, 2013 02:53 PM
MugenHonda
Nov 5, 2010 05:33 PM
deepdownpaul
Nov 5, 2009 09:21 PM
dalejrfan88
Oct 29, 2008 12:35 PM
