NE1 who installed SPRINGS there self, please read
On a coupe, do you need to use a spring compressor or not. my friend said that he didn't use one on his 94 hatch but everyone that I ask at local shops says to a spring compressor.
What did you do?
What did you do?
I wouldnt pull the fronts apart without a compressor.
I dont feel it is safe. the rears arent bad , much softer / shorter springs.
I didn't use a spring compressor either. Just use an air compressor and let the nut/washer/top hat, and spring shoot out. Be sure you are out of the way though
[Modified by hired gun, 5:45 PM 11/6/2002]
its what.. $5-$10 to rent a spring compressor for a day, maybe cheaper if you can rent it for just a few hours... just get one!
I have 2 friends that installed them. all they had were impact wrench...and thats it no spring compressor..it DOES help, but its not neccescary
i used a spring compressor. i was going to rent it but just ended up buying one. i can't remember the price, but it was fairly cheap. like around 20 or 30 bucks. not too bad. i'm glad i did too because i installed my springs onto some neuspeed/koni yellows and about a week after the install i decided to lower the rear perches so i would've had to re-rent one anyway.
I installed my GC coilovers in my coupe without a spring compressor. All we did was just line the bottom with towles and let em' shoot out, just stand back.
[Modified by ImShady, 4:47 PM 11/6/2002]
Use a compressor, makes the job insanely easy.
i would use a compressor, w/out a doubt could turn nasty if u slip and u go flyin with the spring!! only costs around £20 (in the uk) and makes life easier, esp. if u need to replace your lowering spring for the o.e. ones again, does make it a longer job though using compressors
Ziatic
21
Apr 2, 2004 04:26 PM
Kirei
Oct 5, 2003 08:30 PM
