2000 EM1 - Retaining cruise control with an EK9 cluster
Old Jan 20, 2016 | 03:39 PM
REDEM1FTW's Avatar
Icon4 2000 EM1 - Retaining cruise control with an EK9 cluster
Hi guys, i was looking at purchasing an EK9 CTR cluster to go into my 2000 Civic Si.
I noticed that my stock cluster (Si) has the green female plug slot (for cruise control) on the rear of the cluster
(Si Cluster)
while the EK9 CTR cluster does NOT.
(CTR Cluster)
my questions is: If i install the CTR cluster into my Si and leave the green plug *unplugged*, will my cruise control still function correctly (despite not having the "cruise control" indicator illuminate on my CTR gauge cluster?)
I would imagine the plug itself serves to complete some sort of a circuit, but i am not sure if that would impede in the function of the cruise control system itself.
If i am NOT able to retain cruise due to the ctr clusters lack of a green socket, how would I go about getting the cruise control to function without the green plug being plugged into the back of the EK9 cluster?
Thanks in advance!
Old Jan 20, 2016 | 03:40 PM
REDEM1FTW's Avatar
Default Re: 2000 EM1 - Retaining cruise control with an EK9 cluster
Any help is appreciated!
Old Jan 20, 2016 | 03:45 PM
tony_2018's Avatar
Fish Twig
Yes it will still function. I've done it before.
edit: or you can swap the internals over to the si cluster.
Old Jan 20, 2016 | 04:09 PM
REDEM1FTW's Avatar
Thanks for the fast reply! Not having the cruise indicator on the cluster does not bother me, as long as it will still function without it (which you so kindly affirmed for me haha).
You mention swapping the internals over to the Si cluster, what would this accomplish? Allowing me to have the cruise control light? I dont quite understand haha.
Once again, thanks for the info man!
Old Jan 20, 2016 | 04:32 PM
tony_2018's Avatar
Fish Twig
You'll retain the look of the CTR and still keep the cc light.
Old Jan 20, 2016 | 04:42 PM
REDEM1FTW's Avatar
Ahh okay i see. Im guessing i would have to get rid of the ek9 "carbon bezel" in exhange for the Si one, because the ctr one blocks out where the cruise control light is on the usdm cluster. Does that sound correct?
Old Jan 21, 2016 | 01:05 AM
tony_2018's Avatar
Fish Twig
If you're good with a carving knife you can remove the block.
Old Jan 21, 2016 | 08:12 AM
trinib20's Avatar
Note
The gauge internal cannot be swapped
The screw hole to attach the gauges to the housing is different between the EK9 and SI
Old Jan 22, 2016 | 11:00 PM
tony_2018's Avatar
Fish Twig
op take pics.
Old Jan 23, 2016 | 08:04 AM
Former User's Avatar
While the EK9 cluster is missing the green connector slot, it has an extra orange connector slot. What is the function of the extra orange connector slot in the EK9 cluster? Is it possibly for cruise control?
Old Jan 23, 2016 | 11:38 AM
Deetz's Avatar
Crazy Honda Guy
I ran a ctr cluster in my em1 for years. Sure no light, but who cares
Old Jan 23, 2016 | 02:11 PM
tony_2018's Avatar
Fish Twig
i believe thats the SRS light.
Old Jan 23, 2016 | 02:34 PM
Isn't SRS the yellow connector slot shared by both clusters?
Old Jan 23, 2016 | 03:08 PM
tony_2018's Avatar
Fish Twig
If you're asking if both clusters utilize the same SRS plug, yes. He could add the CC circuit to the CTR cluster, its just a board, and cut out the led opening on the face of the cluster with a small carving knife.
Old Jan 24, 2016 | 04:32 AM
canadaek's Avatar
The orange plug is for ABS . The cruise light,ABS and SRS all have there own circuit board that is separate from the cluster circuit overlay you can remove them and install them in the Ek9 cluster but it does require disassembly of the cluster and cutting the hole for the plug and indicator .
Old Jan 24, 2016 | 08:42 AM
tony_2018's Avatar
Fish Twig
Nothing a dremel can't handle or a small carving knife.
///EJ6POWER
May 23, 2012 02:30 PM
Project-Ek9
Nov 9, 2008 07:53 AM
crazi_E
May 30, 2007 06:48 PM
ricedoutride
17
Dec 5, 2006 12:02 PM
wallacecrx
Feb 10, 2006 07:59 AM
