Wipers problem
Wipers problem
Bought a 97 civic Hx recently, owner told me the wipers didn't work so I thought it was something easy like the motor. Picked up the car replaced the motor.. Nothing.. Thought maybe it could the wiper switch.. Replaced switch.. Nothing.. Figured it was probably a wiring issue then put both oem switch and motor in and found out one of the wires(green wire I'm pretty sure) wasn't getting power to the switch so I hardwired a wire from the fuse box below the steering column into the wire output that wasn't getting power. It worked for maybe a week then it started making it so I'd have to have the lights on for the wipers to turn on and then it started blowing my stereo and wiper fuses. How should I go about fixing this problem? Not the best with wiring and electricianal stuff
Re: Wipers problem
Re: Wipers problem
Re: Wipers problem
If the wiper fuse was blown, then return to the stock wiring of the Grn/Blk wire.
The Grn/Blk wire in the pic looks damaged or cut.
The fuse box option slot 3 you chose for Grn wire supplies power with key in ACC/ON(I). You should instead use option slot 4.
Re: Wipers problem
Sorry forgot the say that the really light yellow one is the wipers and the light blue one is the stereo that keeps getting blown also.
Re: Wipers problem
Re: Wipers problem
The stock grn/blk never moved. Should I cut and rewire grn/blk wire?
Re: Wipers problem
Then please explain this comment in your first post:
Re: Wipers problem
Took my car to a buddy told me the grn/black wire wasn't getting power to it probably due from being all cut up. So he took that lime green wire and hard wired it from that 3rd socket in the fuse box to the connector of the switch. So both the wires are in the connector that connect to the wiper switch.
lxdriver
11-13-2011 04:24 PM
jxhxb
12-22-2007 06:02 PM
da1lydr1ver
10-08-2007 12:30 PM
