Well my new rear seal leak installed like this?
Old Jan 17, 2016 | 03:03 PM
wasanissanFL's Avatar
Default Well my new rear seal leak installed like this?
I installed a new OEM honda rear seal into my b18c last night and now I'm thinking i may have pressed it in to far. I was thinking it would be a good idea to tap it in more than the original seal so the new seal would have a untouched portion of the crank shaft to ride on. I seated it evenly with no damage to the new seal at all. I just want to make sure that this is okay before i put everything back together this afternoon.
Old Jan 17, 2016 | 03:35 PM
PyroProblem's Avatar
Default Re: Well my new rear seal leak installed like this?
A couple mm shouldn't hurt anything as long as its even all the way around. In the Porsche world, there was an updated rear main seal that came out several years ago, that purposely was installed about 2mm deeper that the original seal.
You should be good to go!
Old Jan 17, 2016 | 04:59 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Also utilizing a 2-3 mm variance is the trick to seal up any crank with a groove.
It's exactly what the factory trained Honda techs do when they find a groove. They install the seal a little deeper.
Old Jan 17, 2016 | 10:50 PM
Thanks for the reassures guys. I'd hate to bolt this transmission back up just to find a leak.
turboLScrx
Engine Machining & Assembly
19
Feb 26, 2019 03:09 PM
wasanissanFL
Jan 20, 2016 03:35 PM
EG-SIXV-TEC
May 2, 2012 06:28 AM
Jesse H
Aug 12, 2002 09:05 AM
GSRwBOOST
Jul 7, 2001 09:15 PM
