Spec definitiion?
Old Jan 12, 2016 | 07:08 PM
1990IntegraLS's Avatar
Icon5 Spec definitiion?
This is the rear toe, alignment spec from my '90 Acura Service Manual.
What does it mean? 2mm toed in, plus or minus 1/2mm
and/or
.080 toed in, plus .04" or minus .08"?
In another part, it seems to say "-" is toed out and "+" is toed in.
This was the original manual for my car. The Japanese never did a great job of translating into English.
Anybody know?
Thanks!
Old Jan 12, 2016 | 10:22 PM
Calif_Kid's Avatar
Default Re: Spec definitiion?
and/or
To me, for the metric measurement, the max toe in is 2mm+1mm (so total of 3mm toe in) and the minimum is 2mm-2mm (so total of 0mm toe in). The tolerance they're using is a bilateral tolerance, with +1mm and -2mm. For the measurement values in inches, the max is 0.080"+0.040" (total of 0.120" toe in) and the minimum is 0.080"-0.080" (total of 0" toe in). Anyway, the main thing is that for the metric tolerance, the tolerances are +1mm and -2mm, and not +/- 1/2mm. if you take 25.4mm per inch, you can convert from mm to inches and see that the values are roughly the same. - Jim
Old Jan 13, 2016 | 06:12 AM
I guess I should've put this in the suspension section....
..but it seems like as close to 0, or dead straight as possible?
..or up to 1mm toed-in.
Old Jan 13, 2016 | 09:31 AM
Calif_Kid's Avatar
No - I don't believe that that is correct. To me, it appears that the target value for toe in is 2mm (2mm toed in), the maximum is 3mm toe in (2+1), and the minimum is 0mm (2-2). 0mm would be straight ahead. I am guessing that that is the total toe (total of both sides). - Jim
Old Jan 14, 2016 | 10:24 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
and/or
Anybody know?
Thanks!
Means the total variance is between 0-3mm max.
In other words 0,1, 2, or 3mm is acceptable,with 2mm being nominal.
Old Jan 14, 2016 | 10:25 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Yes.
texcon
Suspension & Brakes
Aug 5, 2013 06:27 PM
10cjennings
Suspension & Brakes
May 20, 2012 10:16 AM
dgdarien
Oct 10, 2009 06:32 PM
bus stop
11
Apr 14, 2002 07:06 AM
bus stop
Apr 9, 2002 06:43 PM
