Viper 5706v Install Help
Old Jan 11, 2016 | 12:40 PM
jesus sanchez's Avatar
Default Viper 5706v Install Help
Hi. I'm a noob to installing alarms. I was wondering if someone could help me out on installing this alarm on my '95 Del Sol?
Old Jan 11, 2016 | 12:50 PM
tony_2018's Avatar
Fish Twig
Default Re: Viper 5706v Install Help
What do you need?
Old Jan 11, 2016 | 01:04 PM
Well I just purchased the alarm, remote start system and wanted to know pretty much the connections I need to make.
Old Jan 11, 2016 | 01:13 PM
tony_2018's Avatar
Fish Twig
the12volt.com
Look up the wiring diagrams there. Pretty straight forward, just clean up any unused wiring from the alarm, locate all necessary wires by testing with a DMM and make the connections. But if it seems a bit out of your range just bring it to an installer.
Old Jan 11, 2016 | 02:32 PM
This is the diagram for the alarm/remote start system
This is what I found for the wiring on my del sol.
What wired would I connect together?
Old Jan 11, 2016 | 02:33 PM
KiNGDEE206's Avatar
if u cannot comprehend using the wiring diagram and schematics then u should take it to a professional...
Old Jan 11, 2016 | 02:38 PM
vamp_racing's Avatar
Hey whats up guys im doing this alarm right now as we speak... I just need a little info heres were im at 1997 acura integra LS viper 5706 i gotta get the power for his door locks, parking lights, signal for when they open the door to trigger the alarm i wired the remote start already just need a few things any info can help let me know please.....
Happy vtecking
Old Jan 11, 2016 | 02:42 PM
The issue is, I don't understand the technical names on the wiring guide for the viper system.
Old Jan 11, 2016 | 02:54 PM
I see what u need i also need that same thing for an integra do you know were i can find it
Old Jan 11, 2016 | 04:16 PM
Happy vtecking
Could you make a DIY guide with some pix of how you did it?
Old Jan 11, 2016 | 06:18 PM
tony_2018's Avatar
Fish Twig
You don't provide power to the door locks, it requires a negative signal. Clearly shown in the wiring diagram above for the civic. So you go back to the viper alarmm diagram and locate the door lock/unlock negative trigger.
Old Jan 12, 2016 | 08:57 AM
98civdx's Avatar
Master Detailer
12V source is your best friend while doing this. If it wasn't for it I would have been stuck while doing my stealth install.
Old Jan 12, 2016 | 09:19 AM
tony_2018's Avatar
Fish Twig
Amen, they helped me setup the remote start function on the newer model Tacoma's, damn thing requires 2 igntion trigger's to start the engine.
Old Jan 12, 2016 | 01:32 PM
I need help on the parking lights or daytime running lights i dont know where to put #4,or#5 wire on the green plug above the fuse plug i believe its the reb/black wire is this correct?<br/><br/>97 integra LS
Old Jan 12, 2016 | 02:07 PM
tony_2018's Avatar
Fish Twig
You need to post in the integra forum, this is the civic forum.
Old Jan 12, 2016 | 04:46 PM
98civdx's Avatar
Master Detailer
If you can hold off until tomorrow afternoon/evening I'll run out to the garage and will tell exactly what wires went to which.
Definitely should have posted in the Integra forum, but these cars are similar enough.
Old Jan 13, 2016 | 02:53 PM
asinclado's Avatar
You don't use the #4 wire, there is no need to isolate the parking light wire. you only use the white one (#4), and it goes to the red/green wire on the green connector above the fuse box. verify is the correct wire by testing for 12volts whenever you turn on your parking lights. you also need to make sure the polarity jumper on the alarm brain is set to positive (i think is set to positive by default).
Here is a link to your cars wiring info
Old Jan 13, 2016 | 03:23 PM
tony_2018's Avatar
Fish Twig
You mean #5?
Old Jan 13, 2016 | 04:14 PM
asinclado's Avatar
yes, #5 is the one you need to use. sorry.
Old Jan 18, 2016 | 05:50 PM
Yeah i finished the viper 5706v on the integra a couple of days ago idk if its the same as a del sol but pretty much straight forward i havent connected the parking lights yet i need to find the wire you're talking about is it in the Green plug.... But ok i will try that.....
Old Jan 18, 2016 | 05:51 PM
I had trouble with the remote start i didnt know i had to switch the setting from manual to automatic transmission now the thing is flawless but i just need to try the DRL and it will be peachy
Old Jan 18, 2016 | 11:33 PM
tony_2018's Avatar
Fish Twig
Did you even look up the wiring diagram for the integra?
Old Jan 20, 2016 | 02:44 PM
No i didnt look up a wiring schematic i got the info off another thread on honda-tech
Old Jan 20, 2016 | 03:16 PM
tony_2018's Avatar
Fish Twig
Do the damn thing....th12volt.com...plenty of diagrams. How can you not even try to visit that site.
Old Jan 25, 2016 | 02:47 AM
Hey tony... I already stated that i have completed the alarm install on the integra..... A few days ago maybe you didnt read the post!!! Thank you for you're response i did visit 12volts website and found a similar thread but the person that installed his alarm was having different issues and concluded no solution... Thanks man! The alarm is good
Dnguyen21
Audio / Security / Video
Feb 22, 2016 11:40 AM
Dnguyen21
Feb 11, 2016 03:55 AM
92eg_b16
Feb 25, 2008 04:42 AM
Lithel
Oct 4, 2007 08:06 AM
