Help! Broken timing belt
Old Dec 28, 2015 | 04:20 PM
CivicSos's Avatar
Default Help! Broken timing belt
So, I sold my 99 civic ex to a friend about a month ago. The timing belt broke Saturday morning. I had it replaced about 25k miles ago. He and his dad are starting to replace it now. My question is do they need to pull the head to check the valves or is it a noninterference motor?
Old Dec 28, 2015 | 04:25 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Help! Broken timing belt
It's an interference motor.
However, there is a method to test the valves without pulling the head. And that is by performing a leakdown test. If you have any bent valves, you will have severe pressure loss at TDC and will hear the air escaping into either the exhaust or the intake manifold.
Old Dec 28, 2015 | 04:38 PM
NotARaCist's Avatar
I never narc'd on nobody!
And if you don't have an air compressor, you don't even need to do a leakdown. Just replace the timing belt and start it. Does it run right? Good, you didn't bend any valves.
Old Dec 28, 2015 | 06:07 PM
Former User's Avatar
Install new belt and then compression test the cylinders.
Cripton805
Jan 9, 2022 07:15 PM
DC2_ALL MOTA
Dec 5, 2007 03:00 PM
hondatuningboi96
May 27, 2007 03:38 PM
06Xrunner
Nov 25, 2003 09:18 AM
Redline130
Aug 13, 2001 10:09 PM
