97 Esi del sol/B18c4 swap, ABS problem :(
Old Dec 28, 2015 | 08:06 AM
Glyran's Avatar
Default 97 Esi del sol/B18c4 swap, ABS problem :(
Hey!
I have swap a b18c4 engine to My 1997 Esi del sol. And now the ABS goes in over ~50km/h. Its feel not safe. The ABS light does NOT LIGHT. All the sensors look fine and no problem around.
Have anyboby a idé what it could be? Or did somebody do the same swap and have the same problem?
// Carl from sweden
Old Dec 28, 2015 | 08:11 AM
Former User's Avatar
Default re: 97 Esi del sol/B18c4 swap, ABS problem :(
What does "goes in" mean?
Old Dec 28, 2015 | 08:49 AM
Glyran's Avatar
Default Re: B18c4 swap, ABS problem :(
The ABS become active when i brake
Old Dec 28, 2015 | 09:06 AM
How do you know ABS is inactive at lower speeds?
Does the ABS light work at all?
Old Dec 28, 2015 | 09:10 AM
Glyran's Avatar
Becouse i dont feel it in the brake padel, and its "click" in the ECU when the ABS is active, like tick, tick, tick in the ECU :s
The ABS light is working for 100%
Old Dec 28, 2015 | 09:15 AM
Default Re: 97 Esi del sol/B18c4 swap, ABS problem :(
Have you jumped the service connector to check for trouble codes?
Old Dec 28, 2015 | 09:19 AM
Glyran's Avatar
Yes, i have check and no code's pretty strange :/
Old Dec 28, 2015 | 09:27 AM
Please reconcile these statements.
Old Dec 28, 2015 | 11:30 AM
Glyran's Avatar
Okey, when the ABS "goes in" and be active the ABS light does not light up
But i can se when i start the car that the ABS light is working find
Old Dec 28, 2015 | 12:18 PM
Are you able to verify the ABS actually doesn't work under 50 km/h? For example, do the wheels lock up when you slam on the brakes?
Old Dec 28, 2015 | 02:18 PM
Glyran's Avatar
I think i can brake and lock the wheels without the ABS been active. But i'm not shore
I Will check it tomorrow. Do you have an idé what the problem can be? Some other most have the same problem on there b18c4 swap
solfire
Dec 30, 2008 09:25 AM
ludelvr
Jun 4, 2006 12:48 AM
meat
Jul 30, 2003 08:56 PM
Audio28
Dec 22, 2002 11:48 PM
