97 Esi del sol/B18c4 swap, ABS problem :(
Hey!
I have swap a b18c4 engine to My 1997 Esi del sol. And now the ABS goes in over ~50km/h. Its feel not safe. The ABS light does NOT LIGHT. All the sensors look fine and no problem around.
Have anyboby a idé what it could be? Or did somebody do the same swap and have the same problem?
// Carl from sweden
// Carl from sweden
Re: B18c4 swap, ABS problem :(
Re: 97 Esi del sol/B18c4 swap, ABS problem :(
Are you able to verify the ABS actually doesn't work under 50 km/h? For example, do the wheels lock up when you slam on the brakes?
I Will check it tomorrow. Do you have an idé what the problem can be? Some other most have the same problem on there b18c4 swap
ludelvr
06-04-2006 12:48 AM
