95civic d15b7 no start
Old Dec 26, 2015 | 07:06 AM
gerbsgsr's Avatar
Default 95civic d15b7 no start
Hey guys having an issue with my car. It drove great 2 weeks ago put on about 100 or so milea. went to go start It that upcoming Monday and all it did was crank. I heard the fuel pump prime but seemed like I have no spark. Since then have changed cap rotor coil and igniter. It seems like I have spark now cuz it will studder but won't run. I have checked the ground on the thermostat and also checked the timing twice. Everything looks good. What would be my next step.
Thanks in advance for any help
Old Dec 26, 2015 | 07:27 AM
Former User's Avatar
Default Re: 95civic d15b7 no start
Test for bright white spark at all 4 plugs using a new properly gapped spark plug.
Make sure the plug wires are installed in the proper firing order on the distributor cap.
Post the CEL codes.
Old Dec 26, 2015 | 07:32 AM
gerbsgsr's Avatar
Post the CEL codes.
The car is in proper firing order made sure I checked that and there are no check engine lights on
Old Dec 26, 2015 | 07:34 AM
Does the CEL work?
Verify firing order with pictures.
Check for bright white spark.
Old Dec 26, 2015 | 07:40 AM
gerbsgsr's Avatar
Yes it works and yes I have checked firing order with picture can't check spark color cuz I have no one helping me
Old Dec 26, 2015 | 07:42 AM
Where is this picture? Did you post it?
Find somebody to help you.
Old Dec 26, 2015 | 08:01 AM
gerbsgsr's Avatar
Well it's raining right now and I dont have a garage to work on it so I'm can't work on it at the moment
Old Dec 26, 2015 | 08:29 AM
There's no hurry. Post again when you have results.
Old Dec 26, 2015 | 11:49 AM
civic men's Avatar
you really need to check the colour and conditions of the spark
Old Dec 26, 2015 | 04:30 PM
gerbsgsr's Avatar
Alright I'll look into that hopefully tomorrow
okay lets just say the spark isnt bright white what would be the step to fixing that
do i need to get plugs and wires for it
Old Dec 26, 2015 | 05:44 PM
09chaplak's Avatar
Loves Tossing Salad
I'm a little rusty but I believe Ron will tell you to the either test or replace your ICM in the distributor.
Old Dec 27, 2015 | 02:54 AM
eghatch9295's Avatar
Stancetard Hate Monger
coil is a much more realistic possibility, and bench testable.
Old Dec 27, 2015 | 06:59 PM
gerbsgsr's Avatar
The coil is brand new I dought that is my problem
Old Dec 27, 2015 | 08:07 PM
NotARaCist's Avatar
I never narc'd on nobody!
Don't care if it's brand new or not. You still need to follow diagnostic procedures, which you still haven't.
Old Dec 28, 2015 | 07:24 PM
gerbsgsr's Avatar
What you mean I haven't gone through a diagnostic procedure the othing thing I haven't done is check the color of the spark. I went from having no spark to getting spark so I think I have gone through some sort of procedure
Old Dec 28, 2015 | 08:46 PM
NotARaCist's Avatar
No, what you did is called guessing, and replacing random parts. You haven't done anything diagnostic. Everything you have posted so far has been guesses and assumptions. Get back to us when you actually HAVE checked the spark color.
Boosted96gsr
Jan 9, 2012 08:04 PM
JAYDmManny1331
Nov 22, 2009 09:33 PM
j4yzn
Aug 24, 2009 12:45 PM
MATiC
Jan 27, 2007 08:28 AM
gLotex70
May 31, 2003 01:30 AM
