bad distributor
Old Dec 22, 2015 | 09:14 PM
dudesmccool's Avatar
Default bad distributor
Hey guys,
1988 civic sedan will not start.
Pretty sure its getting fuel, positive its getting air, so I suspect spark is the issue.
swapped in a good condition working distributor and that did not fix it. where should I go next for the electrical system? And is there a common week point electrically with these old cars?
Thanks guys!
Old Dec 22, 2015 | 10:25 PM
kayONE's Avatar
Default Re: bad distributor
Main relay
Old Dec 23, 2015 | 09:52 PM
So a bad relay is going to cut the fuel correct? I shouldn't be able to hear the fuel pump spinning and build pressure?
Old Dec 24, 2015 | 04:58 PM
acmoc's Avatar
Yea, relay would not allow fuel
try hitting it a bit see if it goes
Old Dec 26, 2015 | 03:08 PM
So, replaced distributor and main relay. fuel pump makes noise, so its getting power. What else could it be?
Old Dec 26, 2015 | 03:23 PM
acmoc's Avatar
Timing correct?
firing order correct?
Fuel filter not clogged?
Grounds all atached?
No vacuum leaks?
Old Dec 26, 2015 | 03:26 PM
will check all of those, back in a minute
Old Dec 26, 2015 | 03:48 PM
forgot to mention, held spark plugs to cylinder head and there was no spark.
grounds are attached. timing is correct. distributor is most likely good. main relay works. havent checked fuel filter, but loosened fuel line connection on intake man. and fuel leaked out.
I sprayed starting fluid in intake, cranked it, no pops or action indicating spark in cylinder.
what is the next component behind the distributor? i can feel it in my bones that its an electrical problem
Old Dec 27, 2015 | 06:58 AM
acmoc's Avatar
No spark, can be.
Wires
plugs
Dizzy cap
ignitor
rotor
Dizzy itself (bad coil)
Main relay
Check where the spark stops continuity.
screwdriver with a rag, hold it to the plug, to the wire ends, to the dizzy cap plugs.
You should get arc at each point. If not, the problem is at or around that point.
Old Dec 28, 2015 | 10:50 AM
Ayrexxx's Avatar
Do you get any type of flashing codes?
I used to own an EF and I remember something like if you turn the key and wait you should get a blinking code.
Old Dec 29, 2015 | 11:42 PM
thats the thing, no error codes and no check engine light. Which makes me think its something very obvious and simple.
acmoc, I will get the multimeter out and see if I can find power somewhere. On the plugs going to the distributor, I should have power coming through those plugs correct? that would tell me if im getting power to the distributor.
this might turn into a parts car... lol
Old Dec 30, 2015 | 01:55 PM
acmoc's Avatar
No get a crew driver and crank the motor, put the metal end to the contact point to see if there is an electrical arc.
Where there is no arc, that will be where your problem is.
If theres no arc at the dizzy cap, it could be the cap or rotor.
If those are good than it's the dizzy or ignitor.
I's not worth the cost to put in a new ignitor, just get a distributor
Waldron Racing
Nov 26, 2013 06:45 AM
BPDA77
Apr 3, 2013 04:38 PM
wu tang
24
Jul 29, 2008 05:06 PM
bochnak
May 25, 2007 04:03 AM
junya16
Mar 13, 2003 09:14 PM
