no spark....
no spark....
im going to try out a new main relay not sure if that's going to do anything. I've done 2 differant dizzys and 2 ecus. Any ideas?
Re: no spark.... (wu tang)
The main relay controls fuel not spark. Check the coil and igniter in the distributor. Also make sure there aren't any blown fuses and that the distributor connector is getting battery voltage.
Re: no spark.... (RonJ@HT)
is this the black/yellow wire? if so it is getting power. Someone told me the main relay does control some spark to. but i was alittle confused on that part. also the dizzy i have works i know that for a fact. i took it out of a friends running car
The main relay controls the fuel pump and fuel injectors. Is the fuel pump priming?
Check the critical ground wire on the thermostat housing -- loose, disconnected, corroded?
fuel is priming and grounds are good to go. Im wondering if im missing something down under the dash? but i dunno im quite confused though
If you have power to the distributor, no CEL codes (e.g., distributor sensors), and grounds are good, then focus on the coil and igniter and their wires and connectors.
Have you also inspected the plugs, wires, cap and rotor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wu tang »</TD></TR><TR><TD CLASS="quote">Im wondering if im missing something down under the dash?</TD></TR></TABLE>
Check whether fuse 47 (hood) or fuse 31 (dash) is blown.
Are you able to retrieve any CEL codes?
perfect thank you. Also i'm in idot the fuel pump is not turning on. lol so..where is that dang main relay at?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wu tang »</TD></TR><TR><TD CLASS="quote">where is that dang main relay at?</TD></TR></TABLE>
Pull out the glove box and it is on the right.
Re: no spark.... (mattscivic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattscivic1 »</TD></TR><TR><TD CLASS="quote">have fun its all the way under your dash. i might be wrong but it should be on the left hand side.</TD></TR></TABLE>
jsut went tot he car again. Now i have fuel lol. my codes are 20 and 14. I'm not worryed about the 14. car still would not start. no spark still
use a little di-electric grease on the ignitor on the front and back it solved my problem i had no spark and no cel's tried 4 ignitors and 3 coils but all it took was a little lube
panda teggy
11
07-06-2011 01:18 PM
Coltmorris
09-11-2009 12:51 PM
chicows18
21
01-16-2008 09:30 AM
