My Crx hates me
Old Dec 16, 2015 | 09:25 AM
Xampuls's Avatar
Default My Crx hates me
So I bought a Crx last year for a thousand bucks, it had a b16 swap..great, but ever since I got it I haven't been able to make it run correctly, now I got the car running finally and for some reason it won't accelerate. Like I can turn it on and idle and rev while the cars cold but when I try to drive it the Rpms won't climb for some reason, like something's pulling the engine down.no matter how I push the throttle the engine bogs, unless I feather the throttle at 1/3 throttle real fast Rpms will go up a little .. Won't even rev high enough to see if vtec hits, and if it does vtec doesn't pull any harder engine just changes tone like vtecs hitting, the cars running obd-0 still and the ecu shows code #9, that's the cylinder position sensor, could this be my problem? Car also has a deep exhaust tone for some reason not like a Honda I found a connector under the intake that wasent connected to anything and I can't find what it connects to, i recently replaced the fuel pump with an xenocron pump, if that helps with anything any suggestions or help is appreciated im stumped and I'm too far into it now to give up! Thanks
Old Dec 16, 2015 | 09:53 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: My Crx hates me
Originally Posted by Xampuls
...the ecu shows code #9, that's the cylinder position sensor, could this be my problem?
That should be your first priority.
Old Dec 16, 2015 | 09:58 AM
Xampuls's Avatar
I was thinking that also..im ordering a dizzy friday but when i read up on it people say their car still runs fine so i wanted a second opinion
Old Dec 16, 2015 | 03:35 PM
jhmed's Avatar
Icon6 Re: My Crx hates me
I don't think it "hates" you per se, but I hear the yellow ones are cursed...
Old Dec 20, 2015 | 02:16 AM
Xampuls's Avatar
Funny, I have a yellow door...anyways distributor on its way I'll keep the thread posted
Old Dec 20, 2015 | 11:22 PM
kayONE's Avatar
My car does something like that once in a while can't remember code #
But mine just won't go past a certain rpm
(Don't have tach) engine light comes on and after it just boggs out If I keep giving it gas.
I disconnect the positive side on the battery for like 1min or 2 and engine light clears and I'm good. Try it might work.
Old Dec 21, 2015 | 05:43 AM
Xampuls's Avatar
I tried it my cel on dash doesn't work but my ex u still throws codes
Old Dec 21, 2015 | 12:29 PM
Xampuls's Avatar
I think my dizzy is good and it's just the wiring messed up going into the ecu, I'm going to have to read up on this because I'm not to sure but the wiring doesn't look right here, theirs some exposed wiring if you can see it,
This is coming from the dizzy plug going into the loom
Old Dec 23, 2015 | 08:10 PM
Xampuls's Avatar
I got the new distributor in the mail, installed it same way/spot as old one and car still had bogging problem, backfired a couple times...car is still throwing code #9
Old Dec 24, 2015 | 06:08 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Looking at how much rust you have going on that engine bay I am willing to bet the grounds are in very poor shape. Remove all the grounds, particularly the one by the thermostat. Use a rotary tool with a wire wheel and make the aluminum shine again where the ground connects. Do the same with the ground strap, make that shinny metal again. Repeat the process on all engine grounds. Buy silicone dielectric grease and cover the ground with it.
Poor grounds are the Achilles hills of the electrical system on these cars.
Old Dec 25, 2015 | 02:45 PM
Xampuls's Avatar
I'm going to try this after the holidays, I addressed the wiring that was fraying, dident change anything
Old Dec 26, 2015 | 02:42 AM
Xampuls's Avatar
Actually I forgot to mention, when the fuel pump was changed, their was a white substance lining the bottom of the tank, I would compare it to spackle... Now that I think of it this could be the source of the problem? It smells really bad when it runs, like the fuel its burning doesn't smell normal, what's the correct way to get this **** out of my tank? I was gonna drop it and power wash it out?
Old Dec 26, 2015 | 06:54 AM
White_EG1's Avatar
And a good degreaser, I recommend super clean and you should be good.
Old Dec 26, 2015 | 05:14 PM
No Big Whoop
I bought a B16 swapped CRX with a JDM front end for dirt cheap many years ago because they could not get it to run right. Not even the dealer could figure it out. The owner got tired of throwing money at it, cut his losses and sold the car. All it needed was a $5 ground strap.
Old Dec 26, 2015 | 06:02 PM
Xampuls's Avatar
Was it the oem frame/battery/trains ground? Specifics plz I'll order it right now just to try it
Old Dec 26, 2015 | 06:28 PM
No Big Whoop
It was missing the transmission ground strap. The engine was grounding itself through the front mount and making a tiny spark that you could only see at night.
Grounds, grounds grounds.
Old Jan 3, 2016 | 06:35 PM
Xampuls's Avatar
Cleaned the gunk from the gas tank, and changed the fuel filter man was their crud in there...got it to run better but still hesitates alittle and falls on its face partly, like it just doesn't rev freely... Maybe when I changed the distributor I set ignition timing wrong, I just put the dizzy where the old one was aligned, I don't have a timing light but I moved the distributor around today and it was in the middle first when it was hesitating hard then I tilted it tward the firewall and got it to run a little better so that it idled and would rev like it does now... Do I need to jump the service connector in the passenger side? I was turning the car off to ajust .. Any input? Haven't tried tilting the dizzy the opposite way
Old Jan 4, 2016 | 05:18 PM
~sp33~'s Avatar
EFB055
Check your mechanical timing before you play around with ignition timing
KRock459
May 3, 2009 02:08 PM
aojtin
23
Jun 14, 2008 08:13 PM
claytonsmith
Mar 13, 2007 09:53 AM
zc@hybrid
Apr 20, 2004 04:27 PM
crx1856
Aug 19, 2003 11:55 PM
