Swapped in another engine, now it wont start. Ugh.
I got the other engine in.
Wont start. Y7 (same engine that was in there) into a 98 LX. Drove it into the garage w/old engine.
Here is what I have checked so far:
Compression the same across all. (my gauge reads low I am pretty sure but they were all the same)
Plugs are wet so I know it is getting fuel
Checked cam and crank timing. Cam gear is in the UP position and piston moves to TDC
CPS is hooked up.
Hooked up the spark plugs to plugs and sat them on the windshield - got spark
Checked the cap and rotor and wires and they were all good.
Dizzy is on correctly.
T stat ground is on
Valve Cover ground is on
Tranny ground is on
MAP and TPS are not switched - I tired to switch them but the harness doesn't let you.
I am just baffled because I started the car and drove it into the garage so I know the components run and work like they should.
I don't have the axles in, but that shouldn't matter.
Checked fuses even though the first thing I did was unhook the batter after I pulled in the garage.
What next?
CPS is hooked up.
T stat ground is on
Tranny ground is on
What next?
Is the CEL on? Does it work? Does it come on for ~2 seconds when you turn the key to ON(II), then turn off? What exactly is the compression across all four? Do the TDC marks on the crank pulley line up with the marker on the timing belt cover when the cam gear lines up? What color is the spark?
90 is too low for combustion... try another compression test kit with a properly functioning gauge and see if your numbers are more like 170-180... that is what a healthy Y7 should make.
Attachment 516968
Attachment 516969
Well, glad it's running, but orange spark still isn't healthy. It'd be a good idea to do the diagnostics I gave you and fix the problem before it leaves you stranded.
IntegraUC
Feb 16, 2009 08:30 PM
tikishow
Feb 28, 2007 08:52 AM
biggmike2
Jan 21, 2004 10:56 PM
