Swapped in another engine, now it wont start. Ugh.
Brrraaaap!
I got the other engine in.
Wont start. Y7 (same engine that was in there) into a 98 LX. Drove it into the garage w/old engine.
Here is what I have checked so far:
Compression the same across all. (my gauge reads low I am pretty sure but they were all the same)
Plugs are wet so I know it is getting fuel
Checked cam and crank timing. Cam gear is in the UP position and piston moves to TDC
CPS is hooked up.
Hooked up the spark plugs to plugs and sat them on the windshield - got spark
Checked the cap and rotor and wires and they were all good.
Dizzy is on correctly.
T stat ground is on
Valve Cover ground is on
Tranny ground is on
MAP and TPS are not switched - I tired to switch them but the harness doesn't let you.
I am just baffled because I started the car and drove it into the garage so I know the components run and work like they should.
I don't have the axles in, but that shouldn't matter.
Checked fuses even though the first thing I did was unhook the batter after I pulled in the garage.
What next?
CPS is hooked up.
T stat ground is on
Tranny ground is on
What next?
I never narc'd on nobody!
Re: Swapped in another engine, now it wont start. Ugh.
Is the CEL on? Does it work? Does it come on for ~2 seconds when you turn the key to ON(II), then turn off? What exactly is the compression across all four? Do the TDC marks on the crank pulley line up with the marker on the timing belt cover when the cam gear lines up? What color is the spark?
Brrraaaap!
Yes. Yes. I am pretty sure my gauge reads low but it is the same on all 4 cyl. 90psi cold.
Timing marks line up.
Spark is orange.
Spark is orange.
What kind of "not starting"? if u know what i mean
does the starter kick?
or do you turn the key and it simply does nothing?
90 is too low for combustion... try another compression test kit with a properly functioning gauge and see if your numbers are more like 170-180... that is what a healthy Y7 should make.
Attachment 516968
Attachment 516969
IntegraUC
02-16-2009 08:30 PM
tikishow
02-28-2007 08:52 AM
biggmike2
01-21-2004 10:56 PM
