Civic 89 B18C1 Swap
Old Nov 24, 2015 | 01:35 PM
Walterronny's Avatar
Default Civic 89 B18C1 Swap
Hi! i got a ef from a guy i know , he tried to swap B18C1 engine into his EF, he tried, cut some wires,etc. he finally told me if i can get it done. Checked everything i found many cutted wires. was a hard work to get everything good, ok, finally today i deciced to start engine up , everything is good, I adapted oem engine harness to the new engine, used a good chipped ecu working, made a basemap , disabled Vtec sensos, o2 sensor, VSS sensor too because i used a cable vss. everything looks good, start it up really good, but the problem is i got solid cel, the ecu i used is mine and it works good but anyway i tried with other ecu and samething happens, even stock ecu i used lol , samething happens, i dont know what im missing, iat, tps, map, engine coolant sensor ,etc works in datalogging (crome PRO), i dont wire 5 O2 sensor (but it's disabled in crome features) and VTEC pressure and soneloid (dissabled too) yet.
Main relay sounds good and works ok to me. any input should be appreciate it a lot!!
Thanks.
Old Nov 27, 2015 | 04:06 AM
Default Re: Civic 89 B18C1 Swap
nobody?
Panzo274
Honda Civic (2001 - 2005)
Apr 24, 2017 09:18 PM
derkman
Jun 25, 2009 07:09 PM
klickster
Oct 29, 2007 04:15 PM
92whtgsr
Jun 15, 2007 09:48 AM
T-Charged-Civic
May 11, 2005 12:38 AM
