code 6 CEL
Old 11-25-2015, 02:00 PM
sharpie11's Avatar
Default code 6 CEL
so my 1990 crx si had a check engine light about a month ago, code #6, faulty temp sensor, or thermostat, i replaced the thermostat with a Honda one, added fresh coolant, and it went away. now its back, and i noticed after a long drive the bottom hose wont get warm and the CEL comes on and off like every other day...the heater blows cold too but the upper radiator hose gets hot...any ideas?
also the previous owner messed with all the temp sensor wires, its all alligator clipped together, says that has triggered a CEL before and to just wiggle them around, or fix the wires, but the gauge works as far as i know.
Old 11-26-2015, 12:02 PM
bigtimegambler's Avatar
Default Re: code 6 CEL
Your heater core could be clogged. The bottom hose isn't supposed to get hot, Its the fluid coming out of the radiator that is cooled, ready to go back into the motor.
Old 11-27-2015, 05:06 AM
Technical Hero
HondaPartsHero's Avatar
Code 6 is for the ECT. It's the two prong round sensor on the side of your head near the distributor. You also need to properly bleed your cooling system when doing any procedure that involves loss of coolant.
ZcSiR_junkie
08-03-2014 01:07 AM
jasrams
Honda Civic (2001 - 2005)
06-06-2011 04:40 AM
B6tizzleHatch
12-04-2006 10:55 AM
Jesterian
13
12-22-2005 03:12 PM
SOUNDEFFECTS
10-27-2002 07:51 PM
Quick Reply: code 6 CEL
