Which oils/fluids are best for my '91 Accord LX?
Old Oct 18, 2015 | 02:24 PM
ApatheticAccord's Avatar
Default Which oils/fluids are best for my '91 Accord LX?
1991 Honda Accord LX, 2 previous owners. 261k Miles, great maintenance - proof of receipts/repairs over the years, still have car owner's manual, but can't seem to find it.
What type of Transmission Fluid should I use?
I was told ATF DW-1 is the best to use for Hondas, is this a synthetic blend, or conventional? What would be the best to use?
What type of power steering fluid?
What engline oil?
I currently use 5w-30 as recommended, synthetic blend.
What brake fluid?
I use DOT3
What type of octane/grade of gasoline?
I usually use regular 87 octane
Old Oct 19, 2015 | 03:18 AM
hondamark35's Avatar
Default Re: Which oils/fluids are best for my '91 Accord LX?
it came from the factory with ATF-Z1, but Honda has discontinued that and recommends the current DW-1 as the replacement. DexronIII or VI work fine in my experience, but you are only saving a few bucks to use that instead of the DW-1 from the dealer.
anything that says "Honda/Acura compatible." they use a different formulation than other manufacturers. using anything else will destroy the seals. Nearly all auto parts chain stores carry it.
What engline oil?
my philosophy on engine oil: keep it fresh (change it often enough that it's not black when it comes out) and stick to the recommended weights. brand doesn't matter much, but I like to stick with the same one just to control that variable.
What brake fluid?
I use DOT3
Just make sure it's fresh. break the seal and pour it in. don't use stuff that's been sitting on your shelf for a month with the seal broken. brake fluid pulls moisture out of the air. this ruins it. otherwise, like with oil, keep it fresh (off the top of my head i think it's every 60k mi. or 5 years... something like that)
once again I like to stick to a few stations/brands to control that input. anything other than 87 is a waste for your car. there is a quality standard for gasoline and pretty much any nationally recognized name will meet that standard. No-name, mom&pop places are risky. maybe good, maybe flammable trash juice...
Old Oct 19, 2015 | 10:39 AM
Great, thanks for the help!
I found my owners manual, it said to use DexronII, will any Dexron work?
Old Oct 20, 2015 | 06:18 AM
typically they are "backwards compatible." if "II" is recommended, "III" and "VI" will work but not "I".
Old Oct 20, 2015 | 08:00 AM
Appreciate the help, man.
zedlep
Transmission & Drivetrain
Feb 12, 2009 09:45 AM
drumDumber
Sep 7, 2004 06:41 AM
accordracer789
Jun 3, 2004 09:01 PM
FullMetalJacket
15
Mar 23, 2003 08:13 AM
Pure R Racer
Nov 22, 2001 06:50 PM
