Precision 1000cc injectors No Start
Old Oct 10, 2015 | 10:25 AM
rice a roni's Avatar
Default Precision 1000cc injectors No Start
I'm on crome, yes...I don't want to hear about better fuel management.
I had the map scaled for 450cc injectors with 10watt 10ohm resistors soldered in line and I've ran that setup for the past two years.
I just picked up some precision 1000cc injectors low impedance as well (2.4ohms the 450s measured at 2.6ohms) and I can not get the car to start. Figured maybe I flooded the cylinders so I pull the plugs multiple times and I can't smell any fuel no matter what changes I do to the fuel multiplier or the injector offset. I selected the correct injector and played with the offset, tried 0, 30, 48 and 60. Nothing, no start.
Yesterday I had the car running on the 450s for about 30 minutes.
I can hear the fuel pump every time I key on.
Any ideas to help out?
* figured it out...offset needs to be in the 110s as well as precision 1000cc injectors chosen on the injector selection table for precision 1000s to idle.
Old Oct 10, 2015 | 03:20 PM
Default Re: Precision 1000cc injectors No Start
**** it, threw the 450s back in....running fine now.
Old Apr 26, 2026 | 03:22 PM
Cd5f2223turbo's Avatar
hello brother. I know this is a old post and i apologize for flaming it. But I recently just got rc1000cc and I'm having the same issue even with stock honda obd1 resistor box installed.. I was hoping you got it figured out and can lead me in the right direction.. its a long shot but I hope this message reaches you.
SIR_DREAM_KID
Feb 22, 2012 05:26 AM
CLE
Jul 13, 2006 02:25 PM
DeviousCTR
May 10, 2006 03:31 PM
JalopySiR
Mar 12, 2003 10:52 AM
technine
Dec 16, 2002 02:09 PM
