no start - Car won't start unless I unplug injectors
Car won't start. I get no fuel on my y8 and when I unplug my injectors it fruns for a few seconds then dies.
I installed a b16a2 today and same problem. Car won't start unless I unplug injectors but it dies in a few seconds. Help me please.
Re: no start O.o
Yes the fuel pumps and turns over but won't run. And when I unplug the injectors (four clips) it runs but I flood the engine and it dies. I thinking that when the in injectors are in it doesn't let the fuel out. So what controls the injectors to shot fuel? It's can be the ecu cause the b16a2 was just running when I took it out of the crashed Si.
Re: no start - Car won't start unless I unplug injectors
Agreed!...when u unplug the injectors you cut fuel supply...if your engine is flooding with fuel, it will start all of a sudden on the fuel that is in the combustion chamber....if they are plugged in...it is dumping more than recomended fuel
So what is causing the injectors to act in that way? ive change the main relay, fuel pump, and fuel filter. Whats left?
