died an wont start
Hello guys, im new to the honda world, so i just picked up a decent 97 civic coupe, d16y7, 5spd, i love the car, great on gas, normal mods, exhaust, coil overs, intake, header.. now when i drive the car it runs great, fires right up but it acts like when the car is warm it wont fire, juat turns over an over, i checked if i was getting spark and i am.. now i have read that the efi relay or main relay would cause my symptoms... like i said im new to the honda world, om used to carbed v8s so take it easy on me lol... thanks in advance for any help guys an gals
So i did the code trick of jumping a wire on the test port, i got
I got 6-22-41-65-91, now 1 i thinks for the ect sensor the other 2 are for o2 sensors but whats with the vtec codes an the gas fuel tank pressure sensor?? Car is a 97 cici coupe, d16y7 no vtec... could ot juat be the pcm they used??
so i swapped out the p2p that the last owner had in the car, now my motor is a D16y7 so i picked up a p2e which the car should of had in the first place. car runs but idles low like a hair up from 0 so say 2-400 rpm an its not surging its smooth.. does the new ecu need to learn the new fuel curves? like do i need to reset the ecu
ya the cel is on, i have not checked codes yet, how do i set the base idle?? just reset the ecu?? whats the best way to reset the ecu?? i jave read tons of ways buy want to knw what u guys do, just disconnect the batter for 10 mins??
The Rules and FAQ stickies are not optional reading.
https://honda-tech.com/honda-civic-d...sting-3002401/
https://honda-tech.com/honda-civic-d...tions-1998336/
i pulled the codes, 14,41,65.. iirc 2 are for the o2 sensors the other is for my iac valve?? i disnt have that code running the p2p ecu... also im running a y8 intake manifold, would it be because im running the y8 throttle body still??? bought the car this way so its all new to me
<p>An autotragic ECU won't work. You'll throw CEL codes for the TCU. Unfortunately, you also have a Y8 intake manifold, which means you'll have issues with getting a functioning IACV, which is probably why the idiot PO used an EX ECU.</p><p>You need to get a Y7 throttle body with IACV, reverse the throttle plate, block off the IACV port on the back of the Y8 intake manifold, and that should help resolve your next step. Still, though, you need to resolve the issue of having the wrong ECU. Hopefully the PO didn't also **** your wiring harness to hell and back.</p>
Yes I still have the one we spoke about before but this is the tech forum so it's bad practice to be talking about buying and selling parts in here. That said, you should still have the pms we exchanged saved in your inbox if you still need one.
Now, about the technical aspect of your problem. If you didn't have an iacv code with the P2P ECU the previous owner must have done the wiring conversion for a two wire iacv. So in order to use the y7 iacv you'll have to reverse the wiring mod at the plug and the ECU. Hopefully for your sake the previous owner just depinned the extra wire (orange) and left it dangling but there's a good chance it was just cut and you'll have to extend from the cut sections to the pins or replace the wire entirely. I would suggest you take a look at the iacv plug and the ecu wiring and see if you can locate both ends of the orange wire.
so i noticed my 97 civic starting kinda slow today never really paid attention, well stopped at thr store shut thr car off, came back out an wouldnt start.. so i thought hell battery is dead so i pushed started it an she fired right up.. a few mins later shr started running like crap, missing bad. i noticed my dash lights were diming, my speedo an tach did not work, car died an went to restart it an nothing just click.... sound like the alt went out?? starter??
Merrill Balan
Feb 25, 2023 05:24 PM
Christopher Mai
18
Nov 16, 2016 03:11 PM
Bolo_PR
Jul 26, 2012 07:47 PM
