exhaust rattle?... help!!!
Old Oct 2, 2015 | 01:37 PM
ohemgiii's Avatar
Default exhaust rattle?... help!!!
B
Old Oct 2, 2015 | 01:41 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: exhaust rattle?... help!!!
Inspect your exhaust heat shields for rust. Remove them. Inspect your motor mounts for excess play.
Old Oct 2, 2015 | 01:42 PM
ohemgiii's Avatar
hey thanks for the reply! my motor mounts were replaced a couple months back and i've checked the heat shields already.
maybe i shouldnt have said exhaust.. i just thought it might be the exhaust but everything seems to be ok on it
Old Oct 2, 2015 | 01:47 PM
NotARaCist's Avatar
Now that I've actually listened to the noise, that's...that's not a rattle noise. That's a "you have a hole in your exhaust" noise. Inspect your exhaust for cracks and leaks. If you can't find any leaks, look into replacing your muffler. Sounds like you have some cheap **** N1 knockoff on there.
Granted, the speaker on the computer at work sucks donkey ********, so maybe my opinion will change when I get home and listen to it on a proper stereo.
Old Oct 2, 2015 | 01:51 PM
ohemgiii's Avatar
i bought the car with that exhaust on there.. it soundedpretty nice all until that noise started.. then it killed it!!! .. hopefully i can figure it out soon.
Old Oct 2, 2015 | 01:53 PM
NotARaCist's Avatar
The batting within the muffler could have broken.
Old Oct 2, 2015 | 01:54 PM
ohemgiii's Avatar
it only happens when i'm in gear though. in neutral it sounds fine
Old Oct 2, 2015 | 02:00 PM
NotARaCist's Avatar
Because when you're in gear, the engine is under load, and is actually producing exhaust gas with velocity and heat. When you just rev not in gear, there's no load, so heat is lower, pressure is lower, and gas velocity is lower.
Again, though, I can't really get a proper ear on the clip. My opinion might change when I get home from work. Or it might not. In the meantime, check for exhaust leaks, and do yourself a favor and just remove the heat shields.
Old Oct 2, 2015 | 02:02 PM
ohemgiii's Avatar
alright. thanks again for your input. i'll go remove the heat shields now.
Old Oct 2, 2015 | 03:33 PM
ohemgiii's Avatar
B
Old Oct 2, 2015 | 10:14 PM
NotARaCist's Avatar
After listening to it on speakers worth two *****, I'm sticking with "Your exhaust is shitty."
Also, for the love of ****, please figure out which one of your turn signal bulbs is out and replace it, or if you're using LED signals, get an LED flasher relay.
Old Oct 2, 2015 | 10:21 PM
ohemgiii's Avatar
Yeah I ordered a relay. It'll be in soon. No need to be so rude. Damn
Old Oct 2, 2015 | 11:30 PM
NotARaCist's Avatar
I'm so glad that I gave my time to help you tonight, and you decided to act like a child and delete all of your posts. What are you, 12? Do you understand the intent of a web forum? And I haven't even remotely been rude to you yet.
Yet.
Old Oct 2, 2015 | 11:32 PM
ohemgiii's Avatar
Deleted it because I figured it out.
Old Oct 3, 2015 | 03:52 AM
-Justin-'s Avatar
Haha, you deleted the thread content and now no one else can learn from your experience and the advice found in this thread.
Nice.
NotARaCist might be cynical, but he gave you good advice.
ih8speedbumps
Jan 4, 2014 03:17 AM
joeli27
Apr 4, 2010 07:51 AM
the171
Mar 30, 2010 05:14 PM
Teggy00ls
Aug 5, 2009 07:42 PM
Legacy_CPA
Jun 4, 2002 02:15 PM
