Fuel pump repair
Old Oct 1, 2015 | 03:27 PM
Andruw Martinez's Avatar
Default Fuel pump repair
I have a 1987 Honda civic hatchback si that was donated from my family to me for free but with the catch of a broken fuel pump. I wanted to know if it's possible to repair it without taking it to a mechanic and paying a leg for it if so, how. Thank you in advance!
Old Oct 1, 2015 | 06:32 PM
bspeed's Avatar
Default Re: Fuel pump repair
Honda fuel pumps are not rebuildable to the best of my knowledge, the cases are crimped shut.
Order civic fuel pump with filter from ebay. remove rear seat bottom, remove fuel pump cover (4 phillips screws), remove hoses from tank lid, remove electrical connector, remove 6 nuts from tank lid (10mm socket). Lift assembly out (takes a little twist and finesse). Disconnect pump electrical plug, move hose clamp, pull pump and filter assembly from bracket.....now do it all the same in reverse. Should take less than an hour if you have never done it before. You tube videos will show you how to do it as well.
Old Oct 1, 2015 | 06:46 PM
Awesome! Thank you for the help, it's already getting late here so I'll crack it out in the morning. As for the videos, I'm having bad luck trying to find them on my year, but I'll follow your instructions. Thank you once again!
hamizle
Aug 17, 2009 02:38 PM
mitchell_2kSiR
Jun 9, 2008 12:36 PM
KevronsEG
Jul 6, 2007 02:47 PM
ludecrasy87
12
Jan 8, 2007 05:51 AM
o2flow.net
Oct 1, 2006 08:55 AM
