Leaking roof rails? Water woes.
Old Sep 18, 2015 | 08:55 PM
FlewByU352's Avatar
Default Leaking roof rails? Water woes.
97 Civic EX I have water dripping from the A pillar when it rains a lot. It is NOT coming from the sunroof in anyway because I have viewed the leak with the headliner out and panels out. Previously to even rule that out the hole sunroof was dropped, cleaned, and new OEM hardware/lines/fittings installed. It is not coming from the antenna hole, which also has a fresh gasket to rule out, and the windshield was freshly replaced and the leak still occurs.
With that said, has anyone has this problem? The only thing I can think of is that the roof rails (under the black plastic trim pieces) are leaking. Our roofs are simply spot welded and seam sealed. Could it be that the seam sealer has seen better days and has become ports or cracked? Or is there a real culprit that I'm missing?
Old Sep 19, 2015 | 02:23 AM
oneheadlight's Avatar
Default Re: Leaking roof rails? Water woes.
since you said you removed the headliner and saw the leak, then shouldn't it be simple to see the water dripping in via the seams?
Just apply seam sealer to where you observe it leaking.
Old Sep 19, 2015 | 04:38 AM
FlewByU352's Avatar
Nice idea except for it comes in from inside the boxed in pillar and drips through the inside panel overlap that doesn't get sealer. Sealing it there would just make it run down the pillar internally to another point.
Old Sep 19, 2015 | 07:41 AM
ahh.. now I understand.. I had this happen with mine (96) and there was rust in the perimeter around the windshield. Found it after a new windshield was installed. Removed the new windshield and ended up sandblasting the perimeter, seam sealing it, then reinstalling the windshield. I had it coming in via the a-pillar towards the inside of the car and down towards where the VIN plate is.
Old Sep 19, 2015 | 07:48 AM
tony_2018's Avatar
Fish Twig
Can you take pictures of the exact area where you see water coming down?
Randy Castro
Mar 13, 2015 02:20 AM
borrego805
Sep 17, 2014 12:32 AM
Gmmolina
Jun 5, 2014 04:55 PM
tstein23
Honda Civic (2001 - 2005)
May 17, 2014 04:12 AM
itsnotfast
15
Jan 1, 2010 06:28 AM
