D16y8 surging idle
So when I start my car it idles at 1200-1500 rpms and surges after I drive it and the car warms up it will idle correctly at about 800rpms I have cleaned the Iac Valve and it helped a little. When I unplug my Iacv it idles higher and stays there. i ran the codes a week ago and it only ran p0420 I reran the codes yesterday and i have p0420, p1509, p0113 should I replace iacv or any other suggestions other than look it up I have... thanks
<p>Clean the connectors, check for corrosion, and test the wires for continuity. Also check your IAT sensor. While you're at it, check this as well.</p><p>http://www.tegger.com/hondafaq/tsb/civic/x99-029e.pdf</p>
Thanks for all the help, 2000 Honda Civic d16y8 ,I am going to clean up connectors today and I am waiting on my friend to bring a meter. What should my Iacv be at with the meter? Also I tried unplugging my iacv while my car was on and my idle increased to2000 rpms whats that indicate?
Saw my radiator cap so I got a new one and did a coolant flush
valoskater420
Mar 28, 2014 12:12 PM
Bwill9886
Jul 27, 2009 08:43 AM
