Washed engine bay car won't run correctly
Old Sep 12, 2015 | 01:23 PM
niles.nemo's Avatar
Default Washed engine bay car won't run correctly
Ok so last night I decided to wash my engine bay in my 96 gsr that I bought last week
I covered the dizzy and proceeded to degrease the **** out of everything
After I was done I started the car and drove it back up to the garage
Then I completely dried everything with a air hose, I pulled all the spark plug wires and dizzy caps and blew them out
Pulled the spark plugs and blew out the sockets and blew out the alternator
This morning I get in to go to work and the car won't go over 2000rpms
I step on the throttle and it goes to 2k then back to 1k even if I hold the pedal to the floor the Rpms just keep fluctuating between 1k and 2k I can't even drive it around to try and get it warmed up.
So I pulled the dizzy cap and blew it out checked all the fuses and pulled the alternator and I am going to go have it tested
Please help!!! ASAP I need to go to work tomorrow I can't miss two days in a row
Is there a throttle position sensor or fuel map sensor or mass air flow sensor somewhere that I could have gotten water in?? Help help help 😭😭😭
1996 Acura integra gsr
Swapped b20b1 non vtec from 97 crv
Video of the issue
http://youtu.be/yiuqDJJT_mY
Last edited by niles.nemo; Sep 12, 2015 at 01:45 PM. Reason: Forgot to add motor and car specs
Old Sep 12, 2015 | 02:09 PM
rudebwoy's Avatar
Default Re: Washed engine bay car won't run correctly
pull the spark plugs blow out the holes and wires. water probably causing the spark to contact the ground.
Old Sep 12, 2015 | 02:28 PM
niles.nemo's Avatar
I already did all of that
I'll do it again and I'll spray some brake cleaner down in the holes and try and Evaporate all of the moisture out with it
Old Sep 12, 2015 | 02:47 PM
niles.nemo's Avatar
Ok well I pulled the distributer and wires and have them sitting in the sun and I pulled the spark plugs
Sprayed brake cleaner in the bottom of the sockets to try and evaporate any moisture in the bottom got new plugs
Old Sep 13, 2015 | 04:04 AM
rudebwoy's Avatar
is it running right yet?
Old Sep 13, 2015 | 04:15 AM
baramund's Avatar
Video of the issue
spray wires with wd-40 (displaces moisture)
Old Sep 13, 2015 | 12:08 PM
niles.nemo's Avatar
OK so I ended up going in buying a brand-new distributor and alternator and all new spark plugs and put it all back together it still wouldn't run . So I decided I was gonna let it air out for couple more hours what a waste of time.
So I pull out the throttle position sensor on the back of the throttlebody it was soaked took it, completely dried it cleaned it with sensor cleaner and put it back in. Car runs perfectly fine now
Old Sep 13, 2015 | 12:36 PM
h22integra.eire's Avatar
You will need to set the tps when you put it back on
Old Sep 13, 2015 | 12:37 PM
niles.nemo's Avatar
I marked the top of the tb and the sensor so I could line them up and not have to readjust it
Old Sep 25, 2015 | 02:34 AM
opc's Avatar
opc
bring it to a shop.. ?
Old Sep 26, 2015 | 01:04 PM
holmesnmanny's Avatar
I can't understand why anyone in their right mind would spray water into an engine bay with a thousand electrical components. If I ever did this I would wait a month to let everything atleast have an attempt to dry out before restarting it.
Old Sep 26, 2015 | 03:56 PM
White_EG1's Avatar
X2 I degrease my bay by hand... It takes time but atleast then you won't have these problems.
When I was working in detailing we had countless issue were we would pressure wash a cars engine bay, usually year 99 and under. Sometimes it would go smooth but I wouldn't take that chance on my own car.
Old Sep 27, 2015 | 01:07 AM
Sl0wGSR's Avatar
glad you found the problem...always a relief isnt it... And....That's not a GSR.. Just Sayin.
niles.nemo
Sep 13, 2015 12:23 PM
cooljnateman
Jan 10, 2010 04:55 PM
AedanM
Nov 2, 2009 02:23 PM
S2k ALeN
Oct 13, 2003 01:09 PM
