Squeaky clutch problem SOLVED!
Old Sep 4, 2015 | 01:58 PM
Javelin's Avatar
Default Squeaky clutch problem SOLVED!
After trying all the usual solutions:
Greased the clutch slave cylinder and clutch fork/pivot area. Lubricated the clutch master cylinder rod with silicone spray. Replaced throwout bearing, clutch, and clutch master cylinder.
I finally got rid of that annoying clutch squeak by putting some high-temp grease on the clutch pedal pin! (The Helms manual even states lubricating this pin)
I found this pic from one of the threads here on HT.
Hope this helps!
Old Sep 4, 2015 | 02:13 PM
Tubby 66's Avatar
Default Re: Squeaky clutch problem SOLVED!
Nice! I need to do this. Thanks.
Old Sep 4, 2015 | 03:46 PM
wunfstgsr's Avatar
Loved
Community Favorite
Same here, mine squeaks as i push in the clutch, i believe i need to lubricate the clutch master cylinder rod..
Old Sep 4, 2015 | 04:10 PM
TOO MUCH TORQUE's Avatar
You dont want to do that. The rubber and rod will make even more noise later if you apply grease there....It's not a place you NEED to grease.
Old Sep 4, 2015 | 04:55 PM
Javelin's Avatar
^X2!
Do not lubricate the clutch master cylinder rod. I did and it didn't do jack squat lol.
@wunfstgsr: I had the same issue as you did and lubricating the clutch pedal pin did the trick for me.
Old Sep 4, 2015 | 05:45 PM
wunfstgsr's Avatar
Loved
Community Favorite
Originally Posted by Javelin
^X2!
Thanks ill try that pedal pin, its just it has the sound as if its dry when i push the pedal in as if theres no lubrication so thats why i figured the rod is what needs the lube.
Old Sep 8, 2015 | 05:52 AM
EnjoyTheRideDC2's Avatar
The master cylinder rod is self lubricated by the brake fluid in the reservoir. Putting anything else on that rod could cause the rod seal to prematurely fail from contamination.
Old Sep 24, 2015 | 10:26 PM
chemo523's Avatar
Hope this helps!
Do not use grease, grease will eat away at the rubber. Silicone paste NY 3m is best for this situation
Old Sep 26, 2015 | 11:53 AM
wunfstgsr's Avatar
Loved
Community Favorite
So you simply pull off the cotter pin and pull out the pedal pin and cover it with the grease or silicon paste and reinstall? might have to try this soon.
Old Sep 29, 2015 | 06:10 AM
The pedal pin isn't in contact with any kind of rubber.
Old Sep 29, 2015 | 06:12 AM
It's as simple as that. Hi temp urea grease is what the factory recommends. (Same stuff used for the clutch slave cylinder and clutch fork lubrication points.)
Old Sep 29, 2015 | 06:16 AM
If you dont want to spend the $10-$15 at the dealer for this grease, pick up John Deere Multi-Purpose SD Polyurea Gun Grease - TY6341 for around $5 a tube. Works just as good.
Old Sep 29, 2015 | 07:17 PM
wunfstgsr's Avatar
Loved
Community Favorite
Sweet!
DenisR
Feb 19, 2016 05:09 PM
D16Clunkin
13
Dec 22, 2006 05:43 AM
b16a4
Nov 18, 2006 11:04 AM
Komakazi_830
Dec 5, 2005 04:53 PM
s1ngle
13
Sep 21, 2005 12:01 PM
