Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Oil Adapter Sandwich
Old Sep 2, 2015 | 06:20 AM
DaveSi677's Avatar
Default Oil Adapter Sandwich
<p>I know this a long shot asking here but I will be installing 2 gauges Oil Temp and Oil Pressure as well as installing an oil cooler and was wondering what ppl are using.</p><p>&nbsp;</p><p>What brands are good? &nbsp;What are you using and do you like it?</p>
Old Sep 2, 2015 | 01:29 PM
rd2smoker's Avatar
Default Re: Oil Adapter Sandwich
This is actually something I have been wanting to do for a while.....just never did it.....
Old Sep 2, 2015 | 05:16 PM
DaveSi677's Avatar
<p>I'm looking into it now cause I need it done before Global Time Attack next May at Road Atlanta.</p><p>Mishimoto has an interesting option that has 3 connectors so you could use one for oil temp, oil pressure and use the other for the oil cooler.</p>
Old Sep 2, 2015 | 06:17 PM
rd2smoker's Avatar
That sounds sweet...
I want it because I'm O.C.D. for info and feel the more you know the better off you are.
Got a link to a site selling this unit?
Old Sep 3, 2015 | 08:34 PM
DaveSi677's Avatar
<p>Direct from Mishimoto!</p><p>&nbsp;</p><p>Mishimoto Oil Sandwich Plate, by Mishimoto</p>
Old Sep 4, 2015 | 05:14 AM
rd2smoker's Avatar
Okay....that's cool as ice!
Me like!
Old Sep 4, 2015 | 06:43 AM
GrantMC2's Avatar
3 wouldnt be enough though? You need a feed and return for the oil cooler no?
Old Sep 4, 2015 | 11:31 AM
DaveSi677's Avatar
<p>yes 3 wouldn't be enough... it depends on your setup and what you are looking for.</p><p>&nbsp;</p><p>You do need a feed and a return for the oil cooler. &nbsp;My friend mentioned something of being able to slip the last one for the oil temp and oil pressure. &nbsp;I don't know what he means by it but once he lets me know I'll update you guys.</p>
Old Sep 4, 2015 | 11:42 AM
RoadRaceH2B's Avatar
The Mishimoto kit is very overpriced. You can get an entire kit lines and fittings included on eBay for less than $100.
You have the ability to over cool the oil with an external cooler. You should get a thermostatic valve controlled oil cooler, or you may struggle to reach operating temperature at all.
I would also force pressurized mineral spirits through the heat exchanger to clean any metal or debris out. Check your lines very carefully and make sure the sandwich adapter is pointing parallel to the ground or better, needing to go against gravity to unscrew (does that make sense?), that way there's less chance of it unscrewing.
Some kits also include an oil filter relocator, that's what I would do. Leave the sandwich plate on for life and relocate the filter somewhere nice.
Speed Infliction
Apr 10, 2006 10:04 AM
90crxzc
Dec 6, 2003 01:36 PM
Screamer
May 14, 2003 11:35 AM
itr501
Oct 23, 2001 02:41 PM
