Building a '99 b20b non-vtec dohc with 5speed from a CR-V from my '95 Civic EX
Old Aug 24, 2015 | 09:04 PM
Darrell Woods's Avatar
Default Building a '99 b20b non-vtec dohc with 5speed from a CR-V from my '95 Civic EX
I'm now building a B20b non-vtec from my '95 civic ex.
I tore the block down. Hot tanked it and just a Solid Clean up on the block. Re-biulding the the head. Stainless valves, Crower Valve springs, retainers. Crower stage 2 non-vtec cams. Not sure about What induction to use at this is point. I found individual throttle body fuel injection system.. straight bolt on. Add injectors..
Now. This is the Rub..
What do I do about ECU in my '95 civic to make the '99 b20b non vtec engine and 5 speed manual trans
run and Run right???
Old Aug 24, 2015 | 09:15 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: Building a '99 b20b non-vtec dohc with 5speed from a CR-V from my '95 Civic EX
ITB's suck, the cost and headache just aren't worth it. you need your ecu chipped and tuned. pherable.net will chip it, put a base tune on it, and mail it back to you.
Old Aug 24, 2015 | 09:28 PM
What would recommend for the induction?. The engine, trans didn't come with a ECU. And its obd2, I have obd1. What ecu would I need? And how to interface with the existing obd1 wiring??
Old Aug 25, 2015 | 05:27 AM
Apparently I can use my p06 ecu for non-vtec engines. Cool.!
daohgeeonethree
26
Aug 22, 2016 05:45 PM
rashid.aslam
Engine Management and Tuning
Feb 11, 2014 05:26 PM
randomwalk101
Aug 20, 2001 08:24 AM
