JRSC FPR adapter plate
Im working on my jrsc install on my crx and am missing the frp adapter plate. I went to moss motors and tried to order by part number but its unavailable. Does anyone know where I can get one at? Does anyone have the specs on the part so I can have one made? Is there an aftermarket or alternate oem FPR that I can use in the stock location? Is there an aftermarket fuel rail that I can use that would work? Been searching google and haven't really found anything except maybe moving the FPR to the firewall.
I have been reading through the jrsc threads and Jim @ Motorvations use to make one from what others have said. Might be worth a shot to get in contact with him.
Who is Mr Robot?
It's just a plate to rotate the FPR.
You could make one on a simple Bridgeport or if you're handy with a dremel and a drill/drill press you can make your own out of a small piece of scrap aluminum plate.
Or you could buy an aftermarket fuel rail and run a remote FPR and eliminate the need for the plate entirely.
Who is Mr Robot?
Glad to help. That was definitely your easiest solution compared to sourcing or making your own adapter. The bigger plus is you'll have much more precise control over base fuel pressure and depending on which model you get can support enough fuel flow for tons of power so that's one less thing you have to worry about upgrading in the future.
Who is Mr Robot?
I think he has a d series JRSC. They have a different intake manifold design.
OP, I'm going to hope and assume that you aren't running the FMU that originally came with the kit and have moved up to real engine management.
I don't believe Motorvations ever made a fuel rail adapter plate for the JRSC kits... you may be confusing that with the MAP adapter plate, which they still carry.
Another option would be to purchase the AEM 25-303 fuel regulator which is designed for the '90-93 Integra and utilizes a banjo fitting and bolt on the outlet side to turn the discharge 90'. This should clear the JRSC manifold just fine, and would be a clean installation. You will probably have to lengthen the 1/4" fuel return line between the regulator and hardline (at the base of the firewall) because of the new routing path.
I just ordered this one today! i noticed my fuel return line rubs slightly on my skunk2 ultra manifold, i never noticed it until i came across this thread.
http://www.ebay.com/itm/400760850247?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Who is Mr Robot?
I've been debating hydro dipping some parts, just hard to find a pattern I like. I have found some epic powder coat combinations though, one of which I'm thinking about running on all of my cars wheels to say these are all mine lol. Just not sure if the color would work on a blue car, I'm thinking some form of brilliant white for that one.
JRciv
Dec 12, 2004 04:43 PM
