Bringing a 1995 Integra back to life. Please help
Old Aug 10, 2015 | 11:34 AM
Slammerdc2's Avatar
Default Bringing a 1995 Integra back to life. Please help
So I just bought this 95 rs 4dr , its got Crower stage 2 cams tuned p06 ECU and a bunch of other goodies. It sat for 2 years untouched in the previous owners parents driveway till I brought it home yesterday. I am simply just looking for advice and precausion before I put a battery in and try to fire it up and run it ? I've already inspected all of the wiring no critter damage, just looking for some general input . thanks -
Old Aug 10, 2015 | 11:40 AM
Slammerdc2's Avatar
Default Re: Bringing a 1995 Integra back to life. Please help
Old Aug 10, 2015 | 11:46 AM
Slammerdc2's Avatar
Also it has bout a half tank of gas in from 2 years ago is it ok to burn the fuel off ? Will it hurt the engine, and do I need to change the coolant as well? It looks fine..
Old Aug 11, 2015 | 04:19 AM
billabongrob's Avatar
Since you don't know much about the tune, I'd get a couple of gallons of the highest octane fuel you can in there to mix it up, otherwise, turn it over!
Old Aug 13, 2015 | 08:34 AM
ramboPandA's Avatar
If i were you i would just drain the gas. The gasoline itself doesnt go bad, but the additives they put in it. They put different additives for summer/winter etc. Up to you but thats my preferance. Plus gas is a couple of dollars better to know that it is safe.
Old Aug 14, 2015 | 12:37 PM
EnjoyTheRideDC2's Avatar
I'd just fill it up with the highest octane fuel and pour in a bottle of techron fuel system cleaner. You can drain the fuel if you have the time and means to do so, but not necessary,
I'd also suggest you do a quick oil change. Who knows when the last time its been serviced..
Old Aug 17, 2015 | 09:33 PM
Alexpro's Avatar
Just finished my b16a built, half tank gas also... Dropped engine and started - no issues. My opinion, just burn it.
My hatch was sitting with the half tank sense June of 2012
Old Aug 20, 2015 | 10:00 AM
Slammerdc2's Avatar
Fired it up last night , runs perfect. I'm going to pull th head off the weekend and check what pistons it's running I'm so happy with it I took it for a quick run on the highway it seems really fast for a non vtec car. I really like the tune it's running (have no idea what it is ) but the crower 403s are crazy in higher rpm I took it to about 7800 on two pulls and pulls very hard, I also think it has a lightweight flywheel I can feel it in peddle
Old Aug 21, 2015 | 10:13 AM
Why pull the head? If it runs strong, who cares what pistons you're running? Wait till you blow something...
Old Aug 21, 2015 | 10:17 AM
+1 Otherwise we'll end up with another 'Why isnt it running right' thread
Old Aug 21, 2015 | 01:08 PM
wunfstgsr's Avatar
Loved
Community Favorite
I was about to say the same thing, i think if you pull out the spark plug and bring the piston to the top and with a flash light you might be able to see the stamp on the top of the piston. But yea just leave it! if it aint broke don't fix it!
crazyhouse2011
Feb 20, 2013 04:57 PM
enemy no1
16
Dec 12, 2010 07:14 PM
SPOOLINmatt
Aug 9, 2006 04:59 AM
hybridturtle
Mar 22, 2005 04:43 PM
kim_2_da_chee
Feb 5, 2003 09:44 AM
