Got my car dynoed!
Old Nov 4, 2002 | 09:24 PM
Andrew 825SM's Avatar
Default Got my car dynoed!
Went to the dyno on friday to tune my car at 13 psi, but couldn't get it to boost that high. It kept spiking up to 14 from 4-6k rpm and dropping down to 10-11 psi from 6-8k rpm. This is on a gsr greddy kit and the end result was 261 whp / 192 lbs torque. I expected higher hp numbers, but the torque seems decent. Do you guys think its my TurboXS boost controller that is causing the problem or is it the internal wastegate preventing me from boosting above 11. Ill try to get a dyno sheet posted.
Old Nov 4, 2002 | 09:32 PM
HybridKOOP's Avatar
Default Re: Got my car dynoed! (NHB Fighter)
I run a 18G kit with the same manual boost controller.
They suck brother.
Get an electronic controller and go back to the dyno. I run 10psi spikes and back down to 7psi full boost.
Old Nov 4, 2002 | 09:50 PM
Boostin Ex's Avatar
Default Re: Got my car dynoed! (HybridKOOP)
Yeah It seems like most greddy turbos Ive dealed with that are internally gated have around a 3psi spike in them. Ive got the profec a on my 15G and still spike around 2-3psi.
MindLess311
Jun 10, 2011 04:45 PM
Outkast95LS
Apr 3, 2008 01:50 AM
bigdgsr
Jul 7, 2006 09:09 AM
Drew Peacock
Sep 19, 2003 05:58 PM
Snafu-Si
Jul 12, 2003 10:12 AM
