97 integra Ls/GSR overheating under boost pulled head pics below
Old Jul 17, 2015 | 03:09 PM
pamitar101's Avatar
Default 97 integra Ls/GSR overheating under boost pulled head pics below
My integra has been overheating under boost,did a block test for gasses in the cooling system nothing did a dry compression test results were something like 150 180 175 180 i changed the radiator/water pump/all coolant hoses and thermostat with no luck radiator spewing anti freeze all over when cap is off and warmed up so i finally pulled the head and i noticed a slight what looks to be crack/indentation and 1 loose apr stud pics below please tell me your thoughts and diagnosis thanks
Old Jul 17, 2015 | 03:27 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: 97 integra Ls/GSR overheating under boost pulled head pics below
Well if a stud was loose i would guess thats where the leak was. I can't really tell from the pic on the crack so i can't say anything about that or if it will effect anything but it wont hurt to try and replace the head gasket and re set the studs and try it again.
Old Jul 17, 2015 | 07:09 PM
B_Swapped93's Avatar
get rid of that stupid block guard and look up how badly the hampers the coolant system, that's old school tech just like those vafc ****. CSS is the standard now
Old Jul 17, 2015 | 09:23 PM
MotorMouth93's Avatar
10 Year Member
What's the point of that thing anyways? Just to reinforce the very top part of the cylinder walls?
Old Jul 18, 2015 | 04:03 AM
Yup and stop coolant flow pretty much, it does a poor job all around there's much better tech now. Only companies that still sell them really blox and bwr which are both knock off kings to start with.
Old Jul 18, 2015 | 02:11 PM
wunfstgsr's Avatar
Loved
Community Favorite
I seen people use bicycle chains that work better than those!
Egg Driver
May 15, 2010 06:07 PM
masterkill455
May 21, 2009 10:18 PM
CDtegGo
Sep 18, 2006 06:16 PM
sir boostalot
May 25, 2006 10:40 PM
sharkcohen
Feb 4, 2004 10:14 PM
