signs of head gasket trouble? (crappy) pics inside
Old 02-04-2004, 02:21 PM
sharkcohen's Avatar
Default signs of head gasket trouble? (crappy) pics inside
Just wanting to get opinions before I pull the head.
Radiator neck:
Radiator overflow hose:
Coolant resevoir:
"Bubbles" on oil dipstick after idling for a minute (very crappy pic, damn Sony camera):
There is NOTHING floating in the coolant. I'm running Water Wetter in the coolant. Is this left over residue from the Water Wetter, or is this oil residue?
Old 02-04-2004, 02:31 PM
FULLTHROTTLE's Avatar
Default Re: signs of head gasket trouble? (crappy) pics inside (sharkcohen)
Looks pretty normal for some of the cars I see. It may be just that you have gone too long on the coolant and it is starting to go away. The best way to diag a HG problem is with a leakdown or a nice long cooling system pressure test. Defintly do those before you pull the head. From what I see though you dont have a problem yet. If there are no other symptoms yet either then you may just be paranoid.
Old 02-04-2004, 03:07 PM
Hoosier Daddy's Avatar
I would at least do a compression test before pulling the head, my guess is it's going though.
Old 02-04-2004, 07:03 PM
pornstarSR's Avatar
it looks some what normal...the overflow tank being that dark is kind of odd...maybe flush it out...and see if it gets dark again...do a compression test like Hoosier said....
also why are you worried...maybe you could explain the reason why your focusing on this
Old 02-04-2004, 08:13 PM
sharkcohen's Avatar
Default Re: signs of head gasket trouble? (pornstarSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pornstarSR &raquo;</TD></TR><TR><TD CLASS="quote">also why are you worried...maybe you could explain the reason why your focusing on this</TD></TR></TABLE>
Because when I checked my oil, the oil on the dipstick was "foamy", even worse than what the pic above shows. My oil has NEVER looked like that before. So then I checked the radiator and the resevoir, and found the residue in them.
Thanks for the responses, guys. I'm going to do a leakdown test this weekend.
Old 02-04-2004, 08:56 PM
Default Re: signs of head gasket trouble? (sharkcohen)
FOamy oil only means it has lost its anti foaming capabilities. A blown headgasket does not cause this. Milky oil is a blown HG. Like Nesltle Quik.
Old 02-04-2004, 10:11 PM
Patrick's Avatar
Take an oil change, coolant flush, and compression test and call me in the morning.
Really though, do those things and see what happens.
Old 02-04-2004, 10:14 PM
sh!t happens.
G
Default Re: signs of head gasket trouble? (FULLTHROTTLE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FULLTHROTTLE &raquo;</TD></TR><TR><TD CLASS="quote">FOamy oil only means it has lost its anti foaming capabilities. A blown headgasket does not cause this. Milky oil is a blown HG. Like Nesltle Quik.</TD></TR></TABLE>
He is right........ just clean the over flow tank and see if it comes back like that. and do a good coolant flush..
SoCalHatch
07-19-2009 05:42 AM
GotToyota
Honda Civic (2001 - 2005)
11-24-2008 10:18 PM
A Tribe Called Honda
02-21-2008 03:19 PM
turbohb21
09-24-2007 11:36 PM
sharkcohen
02-08-2004 10:14 PM
Quick Reply: signs of head gasket trouble? (crappy) pics inside
