Codes p0135 and p0141
Old Jul 11, 2015 | 09:35 PM
Udrv2slw's Avatar
Default Codes p0135 and p0141
I just bought a 96 honda civic 2 door. D16y7. I have both the up and down stream o2 heater circuit codes. Both sencers are new and fuse 15 is ok. Any other ideas. I only have 5 more days to get inspection lol
Old Jul 11, 2015 | 10:04 PM
Former User's Avatar
Default Re: Codes p0135 and p0141
Do both O2 sensor connectors get battery voltage from fuse 15?
Old Jul 12, 2015 | 06:19 AM
Udrv2slw's Avatar
I believe so. And the dash lights flicker bright and dime really bad to
Old Jul 12, 2015 | 06:35 AM
Jimi Hondrix's Avatar
May or may not solve the issue but worth a try:
Disconnect both sensors and clean internal connections with electronic cleaner/lube spray from radio shack (or cheaper options on line)... then reset ECU by disconnecting negative terminal and turning on light/brights/ and step on brake pedal a few times to drain residual. Reconnect battery and with all electronics (radio, lights, A/C, etc.) turned off... start engine and let idle for few minutes. Hopefully codes will disappear and stay gone (not just temporarily).
Old Jul 12, 2015 | 06:38 AM
Udrv2slw's Avatar
I also now have p1298 im thinking a short.
Old Jul 12, 2015 | 08:54 AM
fuse 15 is ok
Fuse 15 is blown. Read the Fuse 15 TSB.
Old Jul 12, 2015 | 01:49 PM
Udrv2slw's Avatar
I know its sounds odd as this is a problem with a lot of hondas. (Short circuit caused by intake manifold bracket) causing fuse 15 to blow. Theres a buliten for it from honda. But my is NOT blown. It seems to be acting just like that issue but i dont see the short and my fuse is not poping.
Old Jul 12, 2015 | 02:49 PM
Udrv2slw's Avatar
I found the short. But i never blew any fuses . Odd. Now its just o2 bank 1. Witch im assuming is now junk
Old Jul 12, 2015 | 09:31 PM
If there was a short, then fuse 15 was blown.
Old Jul 15, 2015 | 02:30 PM
Udrv2slw's Avatar
There is a short but no fuse in the car is blow including 15. Im not an idiot. Ik it makes no sense.
Old Jul 15, 2015 | 02:35 PM
How do you know there's a short if fuse 15 doesn't blow?
How do you know fuse 15 is not blown?
Old Jul 16, 2015 | 02:39 PM
Udrv2slw's Avatar
Found the issue. Broken wire in blue connection under intake manifold. No more cel so far
Old Jul 16, 2015 | 02:49 PM
^Makes more sense than short. Glad to know the problem is fixed.
richard203
10
Jul 23, 2015 09:50 PM
RedneckRicer
20
Apr 9, 2014 08:19 PM
Civic Racer X 7
13
Jun 1, 2011 04:56 AM
dices543
82
Oct 6, 2010 10:46 AM
NSU.FL
Jan 14, 2009 04:23 AM
