D15B into a 95 DX
Which D15B? There's about 5 of them. If its the SOHC VTEC version you'll just need to wire up VTEC solenoid and VTEC pressure switch. The rest should plug and play.
Also, the P28 ECU will dump a little too much fuel for the D15B VTEC engine. It will run, but a little on the rich side. You should look into socketing/chipping the P28 ECU and running a D15B programmed chip on it.
CivicDynamo94
Sep 13, 2011 05:04 PM
todubbled1
22
Mar 7, 2009 07:12 AM
