00 Civic - I want my Fuel gauge to drop to E with key off
Old Jun 30, 2015 | 03:17 PM
Uzumymw's Avatar
Default 00 Civic - I want my Fuel gauge to drop to E with key off
Hello, within a few days I wonder if It possible to change a fuel gauge that it will works only when the ignition is ON?
I mean, ignition (key) off - fuel gauge falls down:
Next, ignition (key) on - gauge shows the value of fuel:
I hope that I clearly explained what I mean.
Old Jun 30, 2015 | 06:39 PM
Former User's Avatar
Default re: 00 Civic - I want my Fuel gauge to drop to E with key off
What car? What mods? What gauge?
Old Jul 1, 2015 | 12:49 AM
Uzumymw's Avatar
Sorry I forgot to write, Civic EJ6 '00, and gauge from canada civic '97 (looks like EDM gauge), but working dimmer on them
Old Jul 1, 2015 | 05:59 AM
Assuming that the swapped gauge is not designed to drop to E with key off, the gauge is bad.
Old Jul 1, 2015 | 08:43 AM
Uzumymw's Avatar
So I can't change it?
Old Jul 1, 2015 | 09:25 AM
What do you mean by change? You can replace it.
Old Jul 1, 2015 | 10:55 AM
Uzumymw's Avatar
I don't want to change the gauge, I want to improve it that the fuel gauge will be working as I wrote in 1 post:
Old Jul 1, 2015 | 10:58 AM
Improve? Are you saying that your gauge isn't broken? If it is supposed to work like the USDM gauge, it is broken and you either need to replace it or live with it.
Old Jul 1, 2015 | 11:08 AM
Uzumymw's Avatar
So in the USDM gauges after turning off the ignition the fuel gauge falls down?
Old Jul 1, 2015 | 11:09 AM
No, it retains the reading.
Old Jul 1, 2015 | 11:12 AM
Uzumymw's Avatar
I want to change it that after the ignition switched off, gauge will falls down (like in other cars or gauges in 7th generation of Civic). Is it possible?
Old Jul 1, 2015 | 11:14 AM
Default Re: Fuel gauge Civic
You'll need to replace the gauge.
I edited your thread title to reflect the topic of your thread.
Old Jul 1, 2015 | 11:16 AM
Uzumymw's Avatar
Default Re: 00 Civic - I want my Fuel gauge to drop to E with key off
There is no other way?
Old Jul 1, 2015 | 11:19 AM
Not that I'm aware of. The gauge was designed to operate as it does.
Old Jul 1, 2015 | 03:49 PM
tony_2018's Avatar
Fish Twig
Get an s2k gauge, falls to zero everytime you key off.
Old Jul 1, 2015 | 10:14 PM
DieMaster's Avatar
Needs to be About 20% Cooler
My first thought is you could hook up a delay relay that will power the gauge itself (not the whole cluster) for X seconds to let the gauge fall to E and a normal relay that disconnects the fuel gauge sender from the gauge so it will go to E. U could acoplish the same thing with a couple small relays and a micro controller on a small 1" square board.
Old Jul 2, 2015 | 07:14 AM
In theory, this^ would likely work, though the OP would need to figure out how exactly to accomplish it and then decide whether replacing the gauge with one that has the function built in is an easier and/or less expensive solution.
Old Jul 6, 2015 | 03:13 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
^ True. Both are viable options. Replacing the whole cluster, however, would likely not retain an OEM look. And a relay-based solution would also be difficult as the indicator is not as-built to drop precipitously as the OP likely wants (think how slow it creeps up after a fill-up).
Old Jul 6, 2015 | 03:32 AM
Uzumymw's Avatar
If instead of the fuel gauge insert everything from the temperature gauge?
My 93 accord
Honda Civic (2001 - 2005)
May 19, 2017 04:50 AM
maxwellmercer
Oct 20, 2010 01:31 PM
b18 hatch mike
Mid-Atlantic (Sales)
Jan 1, 2008 05:33 PM
*Boostwerks*
Feb 16, 2004 07:25 PM
jasonb
Mar 29, 2003 08:23 AM
