92 honda accord EX
Old Jun 26, 2015 | 11:55 AM
greenwave12's Avatar
Default 92 honda accord EX
I'm having problems starting my car I had a fuel pump that's brand new put in months ago my car won't start seems like when I first started up it'll start but if I was to go in a store and come out to crank the car it won't start I leave it for 2 minutes and try again then it will fire up now it just wont start but it will turn over I replace the fuel pump relay now I can hear it vibrate a little bit but it still won't start what could be the problem
Old Jun 26, 2015 | 12:04 PM
tim73's Avatar
Default Re: 92 honda accord EX
Dang that was a long run on sentance I was running out of breath in my mind just reading it in my head and then when i thought it would end it just kept on going. Phew! SMH
Old Jun 26, 2015 | 12:10 PM
Ok...I'm trying to get help with a car problem, didn't think it mattered how the sentence looks long as anyone knows what I'm needing help figuring out.
Old Jun 26, 2015 | 01:34 PM
holmesnmanny's Avatar
Is it cranking or not ? If it's cranking but not starting you need to check for spark and fuel immediately while the issue is occurring.
Old Jun 26, 2015 | 01:46 PM
its not cranking but it will turn over seems like when I put that new relay in it tried to start
Old Jun 26, 2015 | 03:49 PM
Cranking means its turning over.
Old Jun 26, 2015 | 03:52 PM
Ok, so wat could be the problem then?
Old Jun 26, 2015 | 03:56 PM
Old Jun 26, 2015 | 07:27 PM
scubacamper's Avatar
I just went through all this with my '93 but it sounds like you're having a different issue.
You said u replaced the main relay (under the dash) in addition to the fuel pump?
Old Jun 27, 2015 | 06:51 AM
tim73's Avatar
Well, youre more likely to get help with your question, when your question is easier to read. Those long run on sentances make my brain hurt. Just a bit of friendly advise.
czachry
May 5, 2018 11:27 AM
BillPerry
Nov 16, 2017 05:06 PM
Bulldawgfan00
Dec 7, 2016 05:03 PM
blueeg
Aug 29, 2004 07:25 AM
MyThreeDailyDrivers
Jun 4, 2004 08:25 AM
